Question about Cycling
My kryptonite 1218 combo lock is jammed. can't open it, can't close it, can't reset it.
It is partially opened so that i see the red reset buttons.
SOURCE: Locked dvd tray.
try this steps I think it will solve your problem.
Posted on Jun 28, 2008
SOURCE: wont stay open
I had load of these units and the cure is simple. You need to replace the ribbon to the faceplate as these get damaged due to wear and tear. Every unit i had with this fault, i fixed by replacing this ribbon. Buy the ribbon and surround as the new surround is a modified one to give extra life to the ribbon. Hope this helps, good luck!
Posted on Nov 14, 2008
with the unit off press and hold the stop button and the eject button.
Posted on Apr 24, 2009
SOURCE: Auto sliding door wont completely open or close from the home possition. The door opens half way and the door closes half way.
How do you replace the harness track?
Posted on May 10, 2009
SOURCE: presto combination lock on a suitcase will not open
my mother in law has a norton suit case and needs keys the number on the lock is 332 norton do not excist anymore where can i get replacment keys from?
Posted on Mar 01, 2010
I found 2 Kryptonite combination cable locks out of a storage box and do not remember there combination! Both are open! Is there a way for me to reset combination while there open? Thanks Denys
Probably not. But a simple solution for this is to turn the numbers and listen for a click when the tumbler locks into place. You' should be able to get the combination from both locks by doing this.
Aug 07, 2011 | Kryptonite Kryptoflex 1218 Combo Cable...
I locked my bikes and went on an extended vacation. Now, I cannot remember the combos. Kroptonite Kryptoflex 1218 Combo Cable Bike Lock
if you have forgotten the combo, then the only way to figure out the combo is to 'progress' the lock,, do this by starting at 0000 then 0001,0002,0003 and so on all the way through until the right combo is reached, trying to open the lock at every number. now what will help in the speed of this is if you can at least remember the first number or two,, say that you set the combo to a birth year ( 1977 ) ---- then all you need to do is start at 1900,1901,1902,1903,1904 etc..( just an example ). but a four digit combo will take about 1 1/2 to 2 hours to figure out.
c...
Jan 25, 2011 | Kryptonite Kryptoflex 1218 Combo Cable...
How do I set the combo for the first time. I don't see any instructions? Thanks, Jordan
If the lock is locked then Push the pin in as far as it will go and turn first ring it will click on number and pin will go in repeat for rest If the lock is open close lock and set the pin try to pull apart and then set no to release
Mar 23, 2010 | Kryptonite Kryptoflex 1218 Combo Cable...
I lost the instructions and don't know how to unlock using "original code" and how to create a new code
try all zeros Kryptonite locks come preset to zeros once unlocked there is a small lever inside were it locks together pull it down and set your new combo then push it back up
Oct 17, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
I dont know how to open the lock its brand new????? They failed to give me instructions when they attached to the bike
My new lock didn't come with any instuctions. I followed the link above and located the "bike locks" heading. I found that the question:
- I have a Kryptonite resettable combination lock and can't find the instructions for resetting it. How can I change the combination?
contained a pdf titled :
- Resettable Combination Cable
(red reset buttons inside)
which is not the cryptoflex 1218 but is compatible anyway.
dont hurt your fingers trying to depress the nodules as the diagram says though. to my chagrin i discovered that they will turn easily if you just push them around into place.
here are the instructions:
To set your own combination
Your new lock is preset to open at 0-0-0-5 at the factory.
1. Open the lock by aligning the opening combination
number to the Guide Points and pull out the Lock
Post. (Figure 1)
2. Push down the two Reset Buttons simultaneously
with thumb and forefinger, and turn counterclockwise
until it comes to a stop. (Figure 2)
3.You are now ready to turn the dials to set your
secret combination, such as a phone number, birthday,
etc.
4. After setting your secret combination, turn the
two Reset Buttons again by Thumb and Forefinger
clockwise until it comes to a stop and back to its
original position.
5. Verify your new combination before using your
lock. Insert the Lock Post all the way into the Locking
Port but do not turn the dials. Pull out the Lock Post.
Your lock is ready to use.
6.The reset operation is now complete. Repeat
steps 1-5 anytime you wish to change your secret
combination.
Oct 11, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
We threw out the info that came with our new trek combination lock. now we have no idea how to open it or to reset it.
Try this....
Post. (Figure 1)
etc.
original position.
combination.
Sep 16, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
Cycling Logo
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
