Question about Oreck Dual Power DP460 Upright Vacuum
Where can I buy one? - Oreck Dual Power DP460 Upright Vacuum
Where can i buy an accessorie adapter for the little yellow steam cleaner
the best way is to buy from the manufacturer or supply where you did buy the vacuums.
or go to this place
http://www.cheapestvacuumcleaners.com/intelligent-irobot-roomba/
God bless you
May 16, 2012 | Vacuums
I have a kenmore elite microwave oven model 363 63692301 stoped heating food ;. fan & turntable work. HELP!
Hello, two things. The mega-tron tube is gone south, or the HV diode is open/shorted to ground which will cause to open. If the microwave meta-tron tube is bad then recyle your microwave oven and buy a new microwave oven. One can buy a new microwave oven cheaper than buying a microwave tube. GB...stewbison
Sep 12, 2011 | Vacuums
Can i get a replacement plate for my microwave oven model number MW8625W? dO THEY STILL MAKE THEM?
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend
http://ping.fm/zJDAM
heatman101
Mar 26, 2011 | Vacuums
Gas valve on bottom leaks is there anywhere to get a new one.
heatman101
Mar 14, 2011 | Vacuums
1 heating element is out where can i buy one 2 replace it
How to Buy
heatman101
Feb 19, 2011 | Vacuums
Power switch either stays on or off if you can get it to turn off.
How to Buy
heatman101
Dec 24, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
MY VACUUM HAS A HOLE IN THE UPRIGHT HOSE, IS THERE A REPLACEMENT TO BUY?
Yes, you can buy a new hose from Dyson directly or you can research the part online - it is sold all over but is probably the cheapest if you buy it through Dyson directly. Call their helpline or order the hose from their website.
Jun 10, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
KIRBY g5 wHEEL CHANGE
It is 0.027 inch thick and 0.28 inch inside diameter.
Or just go HERE and buy it. However we ship only PRIORITY and we have 2.00 handling charge so shipping for 0.75 clip will be $7+ but if you will throw in some bags belts - it will make sense.
Tu put it on - I would not buy any special tools. Simply push it onto the axle with tip of pliers. if you end up bending the clip and it does not stay on - use pliers to shape it back to original shape and try again.
Wherever you buy it - buy 2 or 3 just in case if it gets lost.
Good Luck,
Rocky
Apr 06, 2009 | Kirby G5 Bagged Upright Vacuum
Need to buy parts
Per the Manual I received with my vacuum.... try e-mailing Home_Depot@Eup.cn
Mar 06, 2008 | Vacuums
Oreck Dual Power DP460 Upright Vacuum Logo
11 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
