Question about Onkyo DV-CP500 Multi-disc DVD Player
Unit is stuck in stand by - Onkyo DV-CP500 Multi-disc DVD Player
Get the bowl to release from the stand
The only way to unstick it is with more energy. Get someone to hold the motor unit firmly and someone else turn the bowl anti clockwise. There is no magic if it's stuck, just more effort required.
Feb 20, 2015 | KitchenAid K45SS Classic Stand Mixer
Board is stuck in planer and I can't get it out
Unplug the power cord. Then rotate the motor backwards until the board is free. It will take a lot of turns for the unit to free up. Look at the blade to make sure you are rotating the motor backwards.
Nov 25, 2013 | Jet JPM-13CS, 13" Closed Stand Planer /...
I have a Badger Insinkerator Model 5-81A. I put some asparagus ends into it to dispose of them. They were ground up but water is now coming back up when I turn it on. I have lost the directions and...
yes that is right. keep turning the allen wrench untill it turns easily. then push the reset hard and try it. you dhould hear the unit run. if its running and you still have standing water, the the drain lines have plugged.
Oct 22, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Fisher CA-885 Integrated Stereo Amplifier stuck in stand-by mode
Given the heat/cold cycles of the storage area along with humidity, I would first suspect poor solder connections. This is not unusual for units of this age. A general overhaul should restore this to operation. This should be a labor only repair unless the output STK is bad. These units are known for having poor connections at the voltage regulators which cause a DC voltage offset triggering the protection circuit. The overhaul should address this as well.
Keep us posted on your progress.
Dan
Jul 06, 2010 | Audio Players & Recorders
Dishwasher will not intake water
check inside the tub i beleive in the front left corner is a mushroom shaped "float" switch, grab it and try to lift up and down. if its stuck in up position( pasta or other debris has gotten under it), the machine will not allow any more water into the unit
Jan 10, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Denon 500SD
HI
did you get this fixed? I have the same problem. Stuck on stand by doesnt switch on from remote or the unit.
please help
Dec 28, 2007 | Denon DHT500SD System
Dishwasher
Could be a stuck motor. With unit unplugged, tilt unit back and turn blades on motor by hand until they break free.
Nov 11, 2007 | Hotpoint 24 in. FDW60 Free-standing...
P button stuck
The P button is a part of the control board. You should take apart the control board and see whether the P switch was just stuck and you can fix it or you should replace the unit. Good luck!
Sep 10, 2007 | Smeg 24 in. DWF614SS Stainless Steel...
Stuck in Stand-by mode and will not turn on
try to soft reset the recievers by unplug for a while and replug and try power on , or hold up the rear reset butomn and press power at the szame time then release both
Apr 30, 2007 | Pioneer VSX-D912 Receiver
Onkyo DV-CP500 Multi-disc DVD Player Logo
29 people viewed this question
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
