Question about Fantom Computers & Internet
Driver needed for fdu80 fantom drive
Need driver
2 Suggested Answers
  • 5 Answers
SOURCE: I/O error FDU80
Dear Enryc2 I don't know if you have found a solution already but this is what I tried. If this is your bootup drive, disconnect all other drives, eg., CDRom/DvDRW, FDD, USB drives and try to bootup. You may also try to update your BIOS(only if you know how to).
Posted on May 01, 2007
My Fantom 1G GForce is not recognized by my computer, the drive isn't spinning and it is making a ticking sound. Help!
if your computer came with a motherboard disk the drivers could be on it
check all leads that are attached to this external hard drive make sure they are securely seated
click strart control panel administrive tools computer management device manager scroll through all of the devices if you see a yellow question exclamtion ? ! mark or a red X you will need to reinstall the driver right click on the mark select update driver if you can see the usb drive and its
not working ports(com&lpt)right click update driver
if this fails to fix the problem you might need to install a usb 2 or 3 card they can be easily installed and are very cheap
hope this helps
Aug 04, 2011 | Fantom Drives FD GForce MegaDisk 2TB ...
My fantom hd tfd500u16 is no longer recognized by my computer. I get a blue light and I hear the hd spinning. I uninstalled/reinstalled the drivers, replaced usb cord and tried connecting to other...
Is this an inbuilt drive or an external drive? If you're using USB, it needs a USB connection. It shouldn't need drivers as the computer will automatically detect a hard drive.
Have you tried connecting to a completely different computer to see if that recognised it?
Dec 30, 2010 | Fantom Titanium Hard Drive
I can not locate a driver for my Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive. Do you know where?
Your device should not need drivers Fte Fantom/Titanium drives are fully supported by both Windows and Mac OS's.
Try replacing the cable or using a different USB port.
Sorry I cannot be of more help, The drive itself may be damaged, You can test this by physically removing the drive itself from the case and installing it internally to your system....If the drive functions properly, then the problem is within the board inside the casing.
Ed
Jun 08, 2010 | Fantom Titanium II (TFD500C16) 500 GB USB...
My 1 TB fantom green drive driver has been lost, what do i do?
There's no need for any software -- USB devices are designed to be "plug-and-play" -- the Operating System should recognize the device, and make it ready to be used.
Mar 04, 2010 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
Drive no longer recognized by system. Have to open manually and does not read any disks.
It might be either a driver problem or your disk drive dying. Try going to the Fantom website to get and install new driver. Be sure to back up the old drivers first when asked! If this does not work, then your drive might have worn out and you may need to buy a new one.
Dec 05, 2009 | Fantom Drives USB 2.0 DVD-RAM Burner
Server can't detect USB hard drive
Hello, Assuming you're running windows 200 or newer, no drivers required. If it is not detecting in device manager the shell is likely damaged and simply needs to be replaced. If it does show up, and the drive does not the the drive is likely damaged and you will most likely require professional help recovering the files. If the latter is the case please state you location(country and city) and I will recommend an appropriate facility to assist you. Chris
Jun 04, 2009 | Fantom Titanium II (TFD120U2) 120 GB IDE...
Drive not being recognized
Have you tried this in another PC with, say, WinXP? If it worked then it may be 1 of 2 problems:
1) Driver Issue- you may use a compatible driver and not necessarily a "Fantom" driver. WinME needs drivers for these devices unlike WinXP
2) The USB port is not giving enough power to the drive for it to run (a problem common in older PCs). I have an external USB harddisk that needs to use 2 USB ports in my old Dell laptop since 1 USB port can't supply the power it needs. The cable should have a dual-USB jack on one end, this is so you could use the power from the other USB port.
Hope this helps
Jan 20, 2008 | Fantom Titanium II (TFD500C16) 500 GB USB...
Drive NOT being recognized by WinXP
Put your ear to the drive and verify if it is making any strange low level sounds. Check to make sure the usb connection wasnt affected. YOu wont need a driver as it appears to be hardware related. Either the enclosure or drive may be failing.
Oct 24, 2007 | Fantom Titanium II (TFD500C16) 500 GB USB...
I/O error FDU80
Aug 29, 2006 | Fantom Drives M261-7010 (fdu80) 80 GB Hard...
Computers & Internet Logo
15 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
