Question about Samsung BN59-00856A Remote Control
How do I turn off subtitles? - Samsung BN59-00856A Remote Control
How to turn off subtitle without a remote on a polaroid tv
Polaroid turn off subtitles tv Questions & Answers - Fixya
www.fixya.com > Forum > Tags > turn off subtitles tv
Polaroid turn off subtitles tv related problems. ... ...subtitles on certain channels? go into menu or setup on remote there ... Not finding what you are looking for?
Nov 17, 2015 | Polaroid Televison & Video
How to permanently turn off Subtitles?
What you are referring to is closed captioning (CC). This option sometimes is enabled during initial set up so you may have to return to that procedure to disable CC.
Aug 23, 2015 | JVC Televison & Video
My remote, r0335 does not have a cc button, only a subtitle button. How do I turn subtitles ON, not off?
Subtitles are embedded in the medium being viewed; they can't be turned on and off. The "subtitle" button may actually be a CC button.
May 23, 2014 | Televison & Video
Is there a way to remove subtitles in an avi file while converting to vob file using Allok AVI to DVD converter or Prism Video File coverter? If so, please explain. Thanks.
i recommend iDealshare VideoGo which can remove subtitle from avi video files and convert avi to avi or even other video formats like vob, mp3, mkv, wmv, 3gp, mov and etc.
The following a step by step guide on How to Remove Subtitles from MKV Video Files on Mac or Windows
in fact this guide also applies to remove subtitles from MP4, AVI, FLV, WebM, OGV, VOB, MPEG, RMVB, WMV, WTV and etc.
Sep 20, 2012 | Audio Players & Recorders
I have a VBR334. Every time I play a dvd I get subtitles. I then have to turn it off. Is there a default to keep the subtitles off.
I can't get my VBR334 to keep subtitles ON. After I turn on subtitles, if I (a) pause playback, (b) hit the Next button or (c) Fast Forward, the subtitles go away. I have spent many cell minutes with Vizio and even got a replacement unit. Once I updated the firmware, the subtitles started breaking. Anyone else hit this problem?
Jan 23, 2011 | Vizio Televison & Video
Subtitles always on
Hi - welcome to FixYa,
There are 2 methods for changing the subtitle settings on your DVD player.
Method 1.
To turn off the subtitles on your DVD player during playback:
1. Press the "SUBTITLE" button on your remote control
The subtitle button is just below the "0" (zero) numerical key on the remote control. It is marked "SUBTITLE" above the button and the button has "ABC" written inside a white rectangle on it.
2. Use the left "<" and right ">" arrow keys to change the subtitle setting
Each time you press an arrow key the subtitle language will change and eventually the language will read "OFF". The subtitles are now switched off during playback.
Method 2.
To turn disc subtitles off from the main menu:
1. Press the "MENU/LIST" button on your remote control (directly below "STOP")
The main menu will now appear
2. Press the down arrow key on your remote once to highlight "A" in the left hand column of the main menu
3. Press the right arrow key on your remote once to move to the right-hand column of the menu
4. Press the down arrow twice to highlight "Disc Subtitle"
5. Use the left and right arrow keys to change the subtitle options until your required choice is displayed
6. Once set, press the "MENU/LIST" button again to exit the menu.
This should solve your problem, but if you need any further assistance, please post back.
Regards,
BElectric
Nov 21, 2010 | LG RH-4820 DVD Recorder
How do i turn on the english subtitles
there may be a subtitle button on your remote. After pressing if it doesn't work then there mayn't be subtitle available on your dvd disc.
Aug 23, 2009 | Audiovox D1718PK Portable DVD Player with...
Subtitles won't go away
Turn of the closed captioning on your TV menu.
Apr 01, 2009 | Televison & Video
Hi, how do I turn the subtitles off on my dvd player - pushing the subtitle button just gives the 'english' option then says 'invalid key'. I can turn off subtitles on the actual dvd playing but still the...
Some DVDs can't change the Audio or Subtitles in Button of the Remote, try change in the Menu,
Try again with the Remote with another DVD Disc...
Bruno Gamba
Jul 22, 2008 | Televison & Video
Onkyo CS-V720 crazy subtitle
Turn off the closed captioning on your TV.
Apr 17, 2008 | Onkyo CS-V720 Shelf System
Samsung BN59-00856A Remote Control Logo
Henry  Thomas
Henry Thomas
