My Tecovision remote control stopped working. Changed batteries three different batteries and nothing
SOURCE: My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Posted on Jan 01, 2009
  • 43 Answers
SOURCE: I have a Bose remote control RC18S2-27 that
Check your settings on the receiver , it might be off.
Posted on Aug 18, 2009
  • 127 Answers
SOURCE: remote control not working (no functions),
Do the contacts look ok?
you can check if it is working by looking at it with a digital camera
press a button on the remote
if it shows as flashing on the digital camera screen, then you know it is transmitting.
then your problem would be either the device you are trying to operate is not receiving, or the remote is using the wrong code.
if the code is wrong then look it up online. there are some helpful sites that tell you the codes and how to program the remote.
good luck!
Posted on Jan 02, 2010
Testimonial: "Great help its pushed me in another direction"
  • 7 Answers
SOURCE: I have a ViewSonic RC00136P remote control. It
Okay here's the fix.
Remove batteries. Re-install them wrong side in! Don't panic.
Reverse the direction of both the battery cells and install. Press "Power" button a couple of times and a few other buttons a few times. Then remove batteries and re-install the right side in.
Voila.
Posted on Aug 15, 2010
  • 1335 Answers
SOURCE: my samsung remote BN59-00852A just stopped
Try the instructions below. If you need to replace the remote, you can order one from:
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=BN59-00852A&uuid=12967730823440
Before replacing the remote, try the following:
How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the TV unit.
Let me know if you have further questions. Please make sure to rate this solution. Thanks.
Posted on Feb 03, 2011
Can chunghop remote paired tecovision compatible
Check whether there is a set-up code to your TV brand with this remote control. If yes; you can.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 28, 2014 | ColorApples Chunghop RM-50 Universal...
Wii fix guide
Try this link it may help. If not there may be an issue with the console or controllers. Try the controllers on a different wii. Try a different controller with your wii. Wii Remote Not Working or Syncing Correctly Wii and Wii mini Nintendo...
Aug 21, 2014 | Nintendo Wii Remote Controller
Require TV remote control code for Tecovision lcd32ahrdlebc lcd television
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter".
Jul 16, 2014 | One For All Televison & Video
Vizio sound bar 2.0 remote control not working
After only three days I would take it back, or at least take the remote back and try it on a different sound bar.
Jun 14, 2014 | Vizio VO47L 47 in. LCD TV
My remote control for my samsung ps42c450b1 tv has stopped working, changed batteries but still nothing. Any ideas???
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter
Apr 20, 2013 | Televison & Video
Remote code for tecovision
I have a tecovision TV and I have Philips universal remote what are the codes for that TV
Aug 04, 2012 | Televison & Video
On my dish remote for tv 2 sat button stopped working and wont light up. all other buttons work. i have changed batteries but nothing changed. How do i fix this because i dont wan to waste money on an
Kevin rico,
I can definitely check this out with you. Does the SAT button light up when you press any buttons at all? If you press SAT, can you operate the receiver?
If neither of those work then the remote most likely needs to be replaced. If you would like to try that option, just send me an email at thomas.faust@dish.com and i'll assist you further!
Tommy Faust
DISH Social Media Representative
Jul 05, 2012 | DISH Network 142923 Remote Control
Changed the batteries and it just stopped working ,I get nothing
If you have changed the batteries of the remote control, all setup codes previously it have, been resetted. You have to setup the remote to your TV, by it code, once again.
Jun 20, 2012 | Hitachi CLU-4324UG Remote Control
Remote Keyboard and Remote Control have stopped workinh
1- Check all batteries and check all switches sometimes adjusting the switches to a different channel position helps.
2- There usually is a button on all three items, mouse keyboard and transmitter press all three.
3- Re-install drivers usuing a corded keyboard and mouse
Apr 25, 2009 | Microsoft Keyboard, Remote Control
Toshiba TV Remote Control not working
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
Nov 17, 2007 | Toshiba 36HFX71 36" TV
Open Questions:
I'm hoping to get some clarification as to whether the below is correct or whether I have been taken for a ride. My LG was picked up by a repair service because it started displaying horizonal lines with the picture hazily in the background. I undertook some research and learned that in most cases of the boards needed replacing and it wasn't a panel issue (usually panel issues are associated with vertical lines). After having my TV for 5 days the repair service advised that it required a new power board and a small repair required on another board. They repaired the small repair and I was going to purchase a new power board however the TV has been returned to me dead. It now doesn't even turn on. The power/channel/indicator lights at the bottom flash on then switch off automatically. After getting consumer affairs involved, I finally received a call from the sub contractor and aside from a number of different excuses given based on my questioning of each explanation, all were contrary to the initial diagnosis discussed with me in early June. I documented the conversation which I summarise as follows: - he contacted numerous times however I never received any voicemail. I asked why - after "numerous phone calls" he didn't send a txt msg to which he replied that he's not allowed to send messages. - he initially alleged that the power board was repaired and video board needed replacing which I was quoted for. I corrected him advising that I was told and quoted for a new power board ($530) and the video board was to be repaired. He then changed his story agreeing with me and alleged that found and apparently quoted me $445 for a generic power board but I declined....Just to clarify, I never received this 2nd quote which is evidenced within the emails and messages I sent after receiving no response over a number of weeks. - he continued to claim that the TV now has panel problems and is now not repairable. - I recited the discussion the owner had with me which was consistent with the information when he provided me with the original quote of $530. He then altered his story replying that "this is a rare case... The owner doesn't know what he's saying". - When I challenged why I was quoted for a power board when he is now claiming there are panel issues, his response was that a new power board was to test if the panel was cracked!! - I replied saying that the TV was delivered to them with horizontal lines and even after testing should've been returned with horizonal lines however is now dead. - his excuse changed again advising that during testing he short circuited the TV and replacing the power board would continue to short circuit the video board..When I again questioned WHY then was i quoted for a new power board (as per the owners conversation with me) he returned back to stating that it was a rare case! - I told him about the screws missing in the back panel to which he commented that "they" wouldn't have put them back in because "they" assumed I would just dispose of the TV. What I find interesting is that this was his understanding whilst I was led to believe the TV was repaired (pending a new power board). It now makes sense as to why the driver who delivered the TV literally dropped it off and ran advising that he didn't know anything. I never received a service report and asked for it again however am yet to see it. Based on this information, can anybody shed light on what they've done to the TV? Prior to them taking the TV the horizontal lines were consistent with had a faint picture in the background and didn't alter at all. They're claiming that they did nothing and the TV - claiming that the reason why the panel doesn't turn on is because it was kept on while they were testing.
Sep 25, 2017 | LG Televison & Video
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
