Question about Actiontec (GT704WG) Router
Wireless Im trying to set up my xbox360 with the xbox wireless and i need the wep key for my actiontec gt704wg
  • Anonymous Dec 17, 2008
    how do i hook it up to x box live
  • Anonymous Mar 08, 2009
    I can't set up x box live to the router
The WEP key should be on the bottom side of the modem.
Posted on Feb 13, 2008
    Scholar:
  • 193 Answers
The wep key is nothing but the securirt key which the router generated it self so we cant find that if u entered one or try this login to ur router and disable all w/l security and configure ue x-box-rate me solved if its help full
Posted on Oct 29, 2007
SOURCE:
Which # on the bottom of my actiontec is the WEP #?
The WEP encryption key is setup by the user, it is not a fixed key.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jul 10, 2011 | Actiontec GT704WG Wireless Router...
I am trying to install my actiontec gt704wg in windows t 64 bit
You should not have to install any drivers for this equipment to work. If it is wired, plug an ethernet cable from the back of your computer to the router. If it is wireless, you will have to enter the wireless key. If the GT704 is set to default settings I believe there isn't any encryption on the unit (meaning that you can connect without a key). If you still can't connect wirelessly, you'll have to plug in a cable and open your internet browser. Type 192.168.0.1 in the address bar and within the wireless settings you should see the WEP/WPA key.
May 05, 2011 | Actiontec GT704WG Wireless Router...
I have Actiontec gt704wg wireless and am trying to set up my nook. It asks for a password and i dont know it
In order to get the wifi WEP key for your network, turn over the bottom of the modem- the default WEP key is on a sticker-
Bar that, on your pc open up a web browser, type in 192.168.1.1 in the address bar- by default the user name and password are admin and password- go to the wireless tab, and basic security settings- the WEP key would be listed there
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Jan 08, 2011 | Actiontec GT704WG Wireless Router...
How do i find security key so I can use laptop on my actiontec network.
The security key is the WEP or WPA or WPA2 encryption key that is configured in the router's wireless settings. You need to connect a LAN cable from your computer to your Actiontec, open a browser and enter the router's configuration URL then login to the router then go to the wireless settings for this info or to change the wireless settings.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 05, 2010 | Actiontec GT704WG Wireless Router...
Is there a password that I created for my wireless router? I thought it was the "key" numbers/letters on the bottom of the unit. Does this Actiontec GT704WG work with Mac Notepads?
By default the WEP key is on the bottom of the gateway- however to login to the gateway, the user name and password are admin and password
Oct 03, 2010 | Actiontec GT704WG Wireless Router...
Once i open my router how do i actually open the ports for xbox tcp80,udp88,exctra im using a action tec gt704wg wireless router
http://www.actiontec.com/support/product_details.php?pid=40&typ=doc
Your manual above it also shows you how to open ports in there.
Also if you go to http://portforward.com/, they will show you how to do it too. Go to the link below.
http://www.portforward.com/networking/staticip-xbox360.htm
Actiontec Gateways and Routers are compatible with the Xbox. However, it may be necessary to forward the ports used by the Xbox, in the Actiontec Gateway or Router. Without Port Forwarding, the Xbox Connection Test may report a "NAT" rating of "STRICT" or "MODERATE", rather than "OPEN".
It is also explained below...
Aug 21, 2010 | Actiontec GT704WG Wireless Router...
I upgraded the hard drive ram and OS on a 3 year old macbook core 2 duo. Now it won't connect to my wireless network. It will connect to wireless network at the local coffee shop. I have tried rebooting...
All you need to correct is entering in the WEP key for the wireless network- you will connect, but will be unable to browse wirelessly otherwise. The WEP key is found on the bottom of the actiontec- unless you changed it to something else- at which point you would need to log into the modem to find out your WEP key.(192.168.1.1 on a working computer in internet explorer/safari/firefox, un/pw admin, password or admin, admin; wireless settings)
Aug 15, 2010 | Actiontec GT704WG Wireless Router...
What is my WEP key?
open a browser - clear the address bar - type in
192-168.1.1 - then in the password - forget the username unless u set it - in the password type in 'admin' - just admin that's it -
the go to security - - hunt around and you will see your wep numbers - there will be 4 of them most likely - pick one -
Gary
May 08, 2010 | Actiontec GT704WG Wireless Router...
Secure
Use the WEP encryption in the wireless settings, any computer that wants to connect to your network will have to know that WEP key, without entering it they will see secured network and not be able to access it.
Dec 27, 2007 | Actiontec GT704WG Wireless Router...
Actiontec (GT704WG) Router Logo
244 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Hollyecho Montgomery
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
