Question about Vtech Learning Lodge Card
Learning lodge won't allow purchase - Vtech Learning Lodge Card
How do I get the VTech Learning Lodge Navigator back on my computer without the disc?
You might go to the following (VTech) link, select your specific product from the alphabetical tab for the downloadable manual (also here) and look for 'factory reset' in same manual. Hope this helps!
Electronic Learning Toys ' Best Learning Toys ' VTech America LINK:
http://www.vtechkids.com/support/product_manuals/A
Nov 10, 2014 | Toys
Cannot install learning lodge - cannot download content for purchase
Are you getting any error message when installing the Learning Lodge?
To delete info on toy go to Settings>>My Name>>type R-E-S-E-T then tap the check mark on top right corner of the screen. Toy will turn off automatically if reset is successful.
Dec 30, 2013 | Vtech InnoTab 3S The Wi-Fi Learning App...
Computer not recognizing the tablet
Hi Bre. for the registration, maybe you registered the toy to the vtechkids.com website? the registration for the Learning Lodge and the vtechkids.com website is different. If you are sure that you have registered the toy to the Learning Lodge, I suggest that you go to My ACcount. You will be asked for a password. Click the forgot password option and you will see the email address that you used when you registered for a learning Lodge account. As for the toy not being recognized by your computer, try another USB cable 2.0, another USB port in your computer. If that doesn't work, double check under device manager (assuming that you are using a Windows computer) or Disk Utility App (for Mac). Once you are in device manager click Disk Drives and check if you see anything that says vtech. if you do, right click on VTECH nand1 and uninstall. after uninstalling, turn the toy off, unplug it from your PC Plug it back in and turn it on. Try to access Learning Lodge again. I hope this helps.
Dec 07, 2013 | Vtech Innotab 2S Interactive Learning...
SYSTEM PROBLEM FOUND
You need to update the toy. Connect it to your Learning Lodge Navigator. You should be prompted for an update.
Aug 03, 2013 | Vtech MobiGo 2 Touch Learning System -...
Battery and ignition ok but won't turn on
What you need to do is go to vTech's web site and download the Learning Lodge Navigator. Once you load that on your computer, you can sync your vReader with the computer using a USB cable. There's an option to run the calibration tool.
Here's the link: http://www.vtechkids.com/download
Jul 06, 2013 | Toys
I got my daughter a vtech innotab 2 but dnt have the installation cd which has the learning lodge navigator on. does any 1 no where i can get the learning lodge nav frm?
You can find instruction on how to download the Vtech Innotab Learning Lodge Navigator here: http://www.vtechkids.com/support/faq/%7B3A3839B6-B8FC-4109-B51D-E26EAAA31508%7D/lightbox/
Mar 31, 2013 | VTech Communications INNOTAB 2 PINK
Innotab 2s can't connect to computer via USB.
try another USB cable/usb port. if that doesn't work: For windows--check under device manager>>disk drives>>look for vtech nand1>>right click--uninstall>>unplug the toy>>plug it back in>>turn it on>>try to access Learning Lodge again. For Mac>>open Disk Utility while toy isnot connected to toy.>>plug toy to computer>>turn it on>>look for anything that says vtech.if you do go to Learning Lodge--send error report--call vtech
Mar 29, 2013 | Vtech InnoTab 2S Wi-Fi Learning App Tablet...
Can't get Learning Lodge to reconize second device
is the other toy also an Innotab 2? are you getting any error message? You should see a blue circle that says connected on the Learning Lodge.
Mar 19, 2013 | VTech Communications INNOTAB 2 PINK
Is the VTech Learning Lodge Navigator operational?
same problem here trying to download games with the 3 free v coins im lucky enough i got one but cant get anymore couldnt get into download centre at all lastnight i put it down to being busy with everyone trying to get the games
Dec 25, 2011 | Vtech Mobigo Learning System
Vtech Learning Lodge Card Logo
609 people viewed this question
Top Vtech Home Experts
john h
Tom Chichester
Are you a Vtech Home Expert? Answer questions, earn points and help others
