Question about Samsung LN32C350 32 in. TV
Volume automatically lowers to 0
Volume automatically drops to 0. Front control buttons will raise volume but then it drops again. The red "eye" on the front is constantly blinking, like it's getting a signal from another source. I have removed all other sources from room and the issue still persists.
3 Suggested Answers
  • 8457 Answers
SOURCE: I have a new Samsung
Ur signal turner board have short in it.Call for warenty sevice,must replaced the board this is an entermitten problem.
Posted on Jan 10, 2010
SD Tech
  • 14553 Answers
SOURCE: Samsung HL-T6187S SOUND DROPPING TO 0? By itself
If you can get at the controls again----undo or unsolder the micro switch for volume down! Remove it and see if set works.
A no brainer in that if that switch is bad and vol down still displays nothing else would work
Posted on Mar 13, 2012
Sony walkman volume
spray 90% rubbing alcohol from a spray bottle into the volume button area push the button reapeatedly or, turn the knob back and forth then: let it dry for about an hour then try to use it the control should be clean and working again.
Dec 03, 2013 | Audio Players & Recorders
My volume display stays on
The Tv needs to be serviced by a technician.Probably there is a problem with the circuits inside.
Apr 12, 2008 | Televison & Video
Feb 21, 2012 | Samsung HL-T6187S Television
. unable to lower or raise volume, comcast remote on olivia tv
Open the thing up and clean off all the dirt on the volume buttons with a dry rag and clean the remote sensor.  Put in fresh batteries and now give it a try.
Nov 18, 2009 | Televison & Video
Volume control not working
Most of the time one of the switches under the control buttons are bad on the control panel of the TV.
Jul 05, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Shortage?
There is a ribbon cable between the laptop & the screen. It sounds like you have a short in that cable. If you're not good with tedius electronic repairs, it would be best to have a shop repair it.
Mar 25, 2009 | Gateway Computers & Internet
Cannot raise or lower the volume
resorted contacts on bottom of control board.
Feb 16, 2009 | Hitachi 50UX57B 50" Rear Projection...
We have a HP vp15 monitor. Recently we have not had any sound.
Monitor control buttons are located on the front panel of the monitor on the lower right. Make sure that you connect the built-in monitor speakers to the computer, using the audio cable (green connector). The connection on the monitor is located on the back of the monitor. On that monitor I believe the volume button is the second one (from left tot right) on the lower right. Also you may want to check your systems volume on your computer by left clicking one time on the little speaker on the lower right of your screen by the clock.
Hope this helps
-Curtis
Rate It!
Jan 29, 2009 | HP Pavilion vp15 Monitor
Volume trouble
The top button on the control surface, the one with the green flashing LED, is the volume control. When the unit is "ON" pushing the button up or down raises or lowers the volume, simple. When you connect it to the charger that same green light will turn red while charging. If you push the top button forward (up) at the same time you press the lower button (power) the LED will flash 1-3 times. Three flashes is fully charged and one means it's getting low.
This is a great head set. I just sat on mine and broke the ear piece. I'm looking for another as we speak! It's worth more than it's current retail price by far!!!
Jan 27, 2009 | Body Glove Earglove Bluevoice Bluetooth...
Wave on master volume keeps decreasing on its own
I have nver come accross a setting that will lock the volume to a set level before, but here are a couple of possibilities that you may want to investigate for the cause.
  1. Not all programs use the master volume control, so do, but most adjust the sound by the wav output. Put the mixer onto the desktop, open things like winamp, media player etc and adjust the volume controls on those to see what is doing what.
  2. If you have a multimedia keyboard with a volume control on it, make sure when your typing it's not adjusting the volume at the same time. Again, put the mixer on the desktop out of the way and type as you would normally. It could even be just the vibrations from typing setting it off.
See how you go and post back your results
May 09, 2008 | Microsoft Windows XP Home Edition
Samsung LN32C350 32 in. TV Logo
20 people viewed this question
Jerry Greenberg
Jerry Greenberg
