Question about Dometic Refrigerators
Domestic rc1180 My three way fridge/freezer is running on electricity and has lost temp. Freezer has defrosted and even though we are on max setting the fridge part still is not very cold??
    Top Expert:
  • Dometic Master
  • 5,673 Answers
Disconnect thermistor from back board let run if ok replace thermistor if not replace cooling unit
Posted on May 27, 2016
icansurf
  • 72 Answers
SOURCE: Freezer set at 0 degrees, but runs at 19 degrees. Ice Cream melting...
Low on freon/refrigerant maybe.
Posted on Mar 03, 2007
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
SOURCE: Lec Elan Fridge Freezer: Freezer
Check freezer door seal
Regards, Barry
Posted on Feb 26, 2009
  • 306 Answers
SOURCE: fridge is on but not cold. thermostat is on right temp but not fridge and freezer not cold at all
See if frost is on rear of freezer panel. posssible defrost heater ,relay, or timer quit.
Posted on Apr 30, 2009
SOURCE: GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Posted on Jun 21, 2009
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
Westinghouse freestyle fridge &freezer work but warm after being turned off fo 90 days
What happens in that 72 hours is the evaporator coil get's so much frost built up on it that the fan in the evap. freezer fan has no where to circulate the cold air (where the cold is produced). Basically you have a restriction between freez/fridg. sections you have defrost problem> It is one of three things d heater,d t stat, or your d timer.I need the model # to tell you what my sugestions would be and where to start.
Nov 15, 2013 | Refrigerators
Freezer is ok but refrig is at 60f even though it is set at max cool - maytag model mtb1954dro purchased 7-25-00
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Aug 01, 2011 | Maytag Refrigerators
I have an AEG Santo F/F. The freezer works but the fridge doesn't get cold ,even though its on max.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 13, 2010 | Kitchen Ranges
MSD2756GEB maytag. freezer is working properly.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jun 21, 2010 | Refrigerators
Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Aug 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator cools, but not cool enough, even with temp adjustment turned to coldest setting. Freezer only gets down to 0. Fridge at 44 degrees
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 06, 2009 | Refrigerators
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
Refrigerators Logo
21 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
