Question about Kenmore Sewing Machines
Thread keeps freying
Thread freys right by the eye of the needle
5 Suggested Answers
  • 185 Answers
SOURCE: industrial sewing machine top thread breaking
The brother DB 2 series of machines do not use a needle with a flat side. the needle system is DBX1 and are available from size 10 to size 20.
Try using the right needle for the machine and the right size for the thread you are using. this should make it better
Posted on Feb 27, 2008
SOURCE: breaks thread after sewing about 8 feet. Thread is
try changing your tension (loosen) should be between 4-6 don't ever mess with the bobbin tension only the top, if that doesn't work change the needle, or re-threading.
Posted on Dec 20, 2010
SOURCE: my needle don't fit in the right way when you thread it the eye of the needle is to the side
needle--flat side goes to the back of the machine
inserted into the needle holder as far as it can go
Posted on Apr 03, 2012
  • 1564 Answers
SOURCE: thread coming out of eye of right needle on huskylock 910
Hi:
Are you sure it's coming out? Or is it breaking at the needle?
Try replacing the right needle and do a test stitch. If it still comes out of the needle... loosen that threads tension a little.
Posted on Aug 02, 2012
My thread keeps fraying And my stitch platt is fine
Is it fraying at the needle? AVOID using old or bargain bin thread. Could be the needle eye. It may have a burr/nick or the thread is too heavy for the needle eye. If you are sewing coarse fabric, try a needle with a larger scarf that will help protect the thread from shredding.
All About Needles
Schmetz Needles Needle Guide
Dec 11, 2016 | Sewing Machines
Keeping the thread in needle when you begin to sew
after threading the needle pull about 6" of thread out the back under the press foot
that way the thread is jammed under the foot and is held in place for the next thread
bobbin thread should also be out the back
when you have finished sewing then lift the foot and move the material sewed about 6"" away from the foot before cutting the threads
Nov 03, 2015 | Sewing Machines
The thread cassette will push down but won't thread the needle
Threaders have to be right on target through the eye of the needle. You can look and see if the threading wire is to the left or right of the eye of the needle. Adjust the wire with a very small needle nose pliers. Remember, it is very fragile and can be broken by you or a repairman so don't blame yourself if this happens. The mechanism is mostly pushed upwards very hard to keep it in place. Check to be sure it hasn't started to come loose.
Jul 24, 2015 | Sewing Machines
Thread coming out of eye of right needle on huskylock 910
Hi:
Aug 01, 2012 | Husqvarna Huskylock Computerized 910
Breaks thread after sewing about 8 feet. Thread is freyed away
Dec 18, 2010 | White Sewing 1418 Mechanical Sewing...
Top thread on my Brother Limited Edition 350 Sewing machine keeps breaking. Having used the automatic cutter, the thread pulls up and out of the needle when I want to start sewing again. Also the machine...
rethread the machine
try a top thread tension of 3 or 4
change the needle
always keep a thread tail of 3-5 inches on top & bobbin thread & keep the thread pulled back behind needle before starting to sew
always keep the bobbin area clean of lint & loose thread
& check under the needle plate for lint also
you might consider having the machine serviced, since you said it sounds like a tractor
some needle & thread are not compatable-try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 04, 2010 | Brother Sewing Machines
Why does my thread keep breaking out of the needle
try rethreading machine
top thread tension to tight
needle damaged
thread & needle may not be compatable--here's how to check
Oct 06, 2010 | Consew 226R-1
The top thread is fraying, and not stitching. I t...
If the top thread is being struck by the hook it will frey. Take the needle plate off thread the top of the machine, turn it as it would if you were to sew, there is a hook on the bobbin shuttle that will come around to pick up the top thread. that hook should pass a 1/16 or so above the eye of the needle. If that hook pass to soon, or to late it will strike the thread and split it. The needle needs to go all the way down and just begin it travel back up, this allows the thread to make a hoop for the hook to go through. You can adjust the timing by loosning the hold screws slitly and turning the shuttle to the correct spot, go in small movements.
May 18, 2010 | Sewing Machines
Thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Dec 16, 2008 | Simplicity American Denim SA1100...
I've lost my manual and video need threading info
One of the most common mistakes with overlockers is that the threads must always be threaded in order. So if you sew about 1 inch and the thread breaks try unthreading the eyes of the needles rethread the looper and then rethread the eyes of thew needles. If not you will get the same result of sewing about 1 inch and it will break again.
Aug 26, 2008 | Baby Lock Ellure
Sewing Machines Logo
10 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
