Question about Neptune Washing Machines
Water softner doesn't release - Neptune Washing Machines
  • 3 Answers
Using a putty knife open up your washer and see if your holes are clogged on the large plastic ring.
Posted on Nov 16, 2014
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
After each wash the softener drawer full of water
This is quite normal. Unlike the soap drawer, which is an open ended slot where the liquid detergent candrain out or powder be washed out, the softner compartment is a small reservoir that has a raised tube inside it. It relies on water coming into the reservoir and washing the softner upwards, beyond the level of the raised tube, where it then washes down into the machine. Because of the way that this works, it's not uncommon for the water that washed out the softner to remain, filling the reservoir afterwards. Since the softner is more dense than the water, when you refil, the water will be pushed out of the raised tube by the new softner you put in.
This said, if you are noticing more than there used to be, it is possible that there is a slight blockage in the tube. You may want to lift the cover that goes over the conditioner compartment and make sure the tube is free of any blockages or residual congealed conditioner.
Usually, there is a clip at the rear of the soap drawer. Pull the drawer out to its fullest extent, depress the clip and this will allow you to take the drawer all the way out. Then you can clean the entire drawer with ease. Some models have no clip and by putting slight downward pressure on the draw and giving a sharp tug when it is fully pulled out will allow you to remove it - Just use some common sense here, if it doesn't appear to want to come free, don't force it. Come bac here, drop a note on the thread and I will provide some more detailled help :-)
Jul 29, 2011 | Zanussi F1045W Front Load Washer
It doesn't take the softner from the tray
This is a low water pressure issue/ Remove the gauze from the filter at the back of the water inlet and clean out any dirt.
Jun 10, 2011 | Zanussi FS1055W Front Load Washer
The fabric softner release has stopped working
Most likely the fabric soft dispenser is clogged . this happens when you wash alot in cold water the left over fabric softner get very pasty and can clog it up. You can try filling the dispenser with hot water and run a cycle with hot water this should unclog the dispenser .
Nov 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
How do i disassemble the fabric softener dispenser? already popped off of agitator
This softener cup doesn,t come apart.The easiest way to clean it is to throw it in the wash cycle with rags and hot water. Then from here on use less softner . Mix it 50/50 with water.
Aug 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
Adding Softner
try taking the dispenser off and cleaning it might have a build up of old softner
Oct 15, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Softner releasing during first fill up
Has anyone worked on this machine>?? The reason I ask is the disp. is flushed with water by a solenoid valve if the wires were swapped then it could be flushing out the cup when the say it should flush out the soap?/ let me know and we can move on from there
Mar 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Neptune Washing Machines Experts
gbob59
Eric Taylor
Are you a Neptune Washing Machine Expert? Answer questions, earn points and help others
