Question about 2wire Computers & Internet
2wire lost setup cd download for 2701 HG-B drivers installation CD
2 Suggested Answers
SOURCE: xp home won't install 2wire 1701 hg gateway-- need driver?
go to 2wire site and download the driver ...
Posted on Apr 21, 2009
Can the 2701 HG-B handle 6000-plus Kbps?
According to the setup screen, it can handle DSL link speeds up to 10692kbps (down) and 1036kbps (up)
I can't verify that it works, but... that's what it says
Jan 02, 2013 | 2wire 2700HG-B Router (2700HGB)
I have this 2wire 2701 HG B wireless modem router. I have lost its manual. How can i access its settings to disable wireless router
you can ussually surf to the routers configuration page via its ip address
From a command prompt type IPCONFIG and the default gateways 'should" be the router's IP
Feb 04, 2011 | 2wire (2701HG-B) Wireless Router
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
My 2wire router 2701 HG-B drops the wireless connection when someone calls on the home hard wired line. Is there something wrong?
Your wall filters may be plugged in wrong. Verify they are plugged in correctly. This is likely the problem.
Oct 01, 2010 | 2wire (2701HG-B) Wireless Router
Is the DWL-520 Wireless Adapter compatible with the 2701 HG modem
The 802.11b and 802.11g Wi-Fi networking standards are generally compatible. An 802.11b router / access point will work with 802.11g network adapters and vice versa.
There is no such conflict reported with the above devices. But as suggestion use an 802.11g wireless card with the Bell as it would give you better performance
Thanks for using Fixya
proton
Jul 27, 2009 | D-Link Air DWL 520 802.11b (DWL-520)...
Install 2wire 1701hg without installation CD
1. pull up browser(ie internet explorer)
2. type 192.168.1.254/setup or http://homeportal/setup in the address field. (click on i forgot my password if you forget it. then if you can't figure out the pw with the hint provided then go click on " i still forgot my password". you can then reset the system password)
3. setup your 2wire 1701 page, double check if key codes are there. it should be 522P-22P4-6262-22AT-F2NV
4. In time zone page, just choose the one then click next.
5. setup connection info page, just make sure the username is your primary email address with your ISP and also the correct password. fill out the username and password and confirm password fields ONLY then click next. And you're DONE!
you just have to wait till it successfully establish a connection.
if you're still having problem after doing that maybe twice or more then i suggest giving your ISP a call. they can also send you the 2wire cd if your ISP supports 2wire modem. AT&T does.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 06, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
I have the same modem.
You don't need any installation cd.
Just follow the instructions at this web page:
http://support.2wire.com/?page=view&article=60
Nov 04, 2008 | 2wire (1000-400108-001) Router
Computers & Internet Logo
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
