Question about Music
Jbl decade t595
Can i connect jbl t595 speakers to blaupunkt hamburg m57
How do i link 2x tr125 jbl speakers to 2 mr922 jbl speakers
The connections are pretty straight forward, but it will depend on what amplifier you're driving them with. Normally, I'd connect the two TR to one side of a stereo PA amp and the two MR to the other side. All four cabinets are rated at 8 ohms, so running tow parallel per side would give you a 4 ohm load on each channel which would be a common load for most stereo PA amps.
However all this would depend on your gear and what you need to accomplish. If what your question really meant is how do you connect all 4 to one channel, you can't as in most cases the total impedance would be too low and you'll fry your amp.
If you can be more specific about your system we could be more helpful.
Mar 17, 2015 | JBL Music
I Bought the Denon Mc2000 Dj Controller, The Place Where i dj has its speakers coming with 2 RCA cables to plug in plus I have to bring one of my Amplified speakers(JBL EON 15'')... I have tried al...
you are getting reverse polarity, meaning the speakers on one is the opposite as the other, black>red red>black, thus only getting vocals or music.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/ernie_b93ee48ba0eab50b
Oct 18, 2013 | JBL Music
No more subs in jbl prx-512m
First check the speaker with a multimeter.
If it is OK, then check/repair the Class D amp that drives the speaker,
up to the input stage.
There are board part numbers printed on the PCB and some are
available on line.
Have a tech to guide you ,should you feel to Diy.
Oct 17, 2012 | JBL New Jbl Prx512m 12 Powered Monitor...
I dont know how to connect my gem sound trf152 speakers
Looks like it takes regular home theatre speaker wire. If this is a powered speaker (like a JBL eon g2), then all you need is a passive mixer, and connect the speakers to the mixer. If this is not a powered (amplified) speaker, then you will need an amplifier to boost the sound source and drive the speakers, so you would connect the mixer to the amplifier, then the amp outs to the speakers.
Apr 14, 2012 | Gem Sound TRF152 15 Pro DJ PA Speaker
Loud buzz/hum started on jbl eon 1500 powered speaker one side only after power cut off and sudden power back on makes same noise on it`s own as well as with mixer etc could this be a transformer...
For some reason the soft on protection circuit has failed. it is not a simple fix and would require the amplifier module to be removed from the speaker to assess the damage.
Mar 10, 2012 | Jbl Eon 515 Eon515 15 Powered Portable...
I have a pair of jbl 512m speakers one is louder than the other one but it works
Make sure your audio interconnecting cables are XLR or TRS balanced lines. Use of TS cables similar to guitar cables with only two conductors (only the tip and the sleeve) reduce the gain 6 DB and contribute to hum and noise.
Sep 03, 2011 | JBL New Jbl Prx512m 12 Powered Monitor...
I have a set of JBL control one speakers and the foam suspention has decintergrated can i get it repaird
You need to have the speakers re-coned. Unless they are really really good speakers this will cost you almost as much as new ones. A JBL authorized repair facility should be your next call. Replacing them is probably the answer
Jan 20, 2011 | JBL Control 2P Monitor Studio Active
Can i connect 2 jbl 300 watt speakers to the mg 100hdfx 100 watt amp head ?
Yes you can as long as the speaker impedance when paralleled doesn't go below the rating of the amp. Marshall seems to hide their design lowest output impedance. Possibly you can find that in your owner's manual. Then find the impedance of the JBL. If half the JBL impedance is equal to or greater than the lowest impedance the Marshall is rated, you are fine to use it. The speaker Watt rating should always be bigger than the amp rating which it is in this case.
Dec 11, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Music Logo
37 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
