Question about GE JVM1653 Microwave Oven
Microwave shuts off - GE JVM1653 Microwave Oven
Stove top light on Microwave will not shut off.
There's a relay in the microwave that is not working.
Oct 01, 2014 | Panasonic Genius Prestige Nn-Cd989s -...
Microwave shut off
At this time we recommend you test the microwave on a different power outlet. If the problem persists, please use the below link to locate an authorized service center.
Welcome to Panasonic Online Repair
Apr 16, 2014 | Panasonic NN-S569BA Microwave Oven
Heating element does not shut off even when microwave is off
All electronics that have relays have a problem with the relays arcing shut. Hit the back of the relay firmly to release it.
Nov 28, 2013 | LG LMVM2277ST Microwave Oven
Microwave shuts off after 22 seconds
Any product that uses electronic parts is subject to failures. That's why warranties exist. Contact Bosch on their webpage to get assistance.
Nov 16, 2017 | Bosch 500 HMB5050 Microwave Oven
Microwave won't start
I have the same problem. Is the light still on inside the microwave? Mine is on and the microwave thinks the door is not shut. I took the top off of the microwave and the latch needs to push down on a switch once shut. The latch was reaching the switch, but I think some spring in the door, pushing the latches down, has broken since it reaches the switch when closed but there isn't any downward force to flip the switch.
I am trying to figure out how to repair the latch but if your light is on when you "shut" the door, you may have the same problem.
Aug 23, 2012 | Cuisinart CWM-100 Microwave Oven
The microwave shut off by itself. Is there an auto shut off? I ask because I was reheating some squash and the microwave shut off. No lights nothing. Sugestions?
Check it after 2 hrs .By repluging it.
If you use microwave alot then it might get too hot,So just try it.
Otherwise give some more detail to me to trouble shoot it.
Thanks
Sep 11, 2011 | Jenn-Air Microwave Ovens
My daughter put metal in oven it shut off. the oven turns buts shuts off after a few seconds. help
metal cannot absorb the microwaves, the microwaves bounce around inside the oven. Eventually they reflect back to the magnetron, which is the part that produces the microwaves. The magnetron can overheat and be damaged.
Dec 21, 2009 | Panasonic NN-T774SF Microwave Oven
Microwave Oven shuts off after 5 seconds
What type of microwave is it (make and model)?
May 25, 2009 | Panasonic NN-S592 Microwave Oven
GE JVM1653 Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
