Question about LG WM-2277HW Front Load Washer
Can you reverse the door on Duet washer ghw9150pwo
Can the door be reversed? ie open from left to right-----hinge on right side If so do you have instructions on how to do it?
Due to the shape of the washer door, and how it seats against the control panel, the door cannot be reversed on the Duet washer. There are no cut outs along the door opening to accommodate the door hinge screws and the door latch on opposite sides. The Duet DRYER, on the other hand, CAN be reversed. This may be an alternative configuration for you. Let me know if you want to know how to reverse the dryer door.
Jun 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ghw9150pwo f11 error code
f11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor
Control Unit (MCU) cannot be sent correctly.
* Check Wire Harness connectors to the MCU, the motor, and Central
Control Unit (CCU)
* Check the Drive system for any worn or failed components
* Check MCU
* Check CCU
* Check Motor
Nov 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer not spinning
It's not really a solution but I checked my paper work from when I purchased the washer and found out that I got the extended warranty, so I have called in a service call.
Jun 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet whirlpool ghw9150pwo
Press & hold the button on right of panel 'end of cycle' for 3 seconds, the light will go off. Child lock. <It will come on again if you dont vote me nice!!>
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GHW9150PWO Whirlpool duet
take bottom panel under door off there 3 screws you 'll need a star tool reach on the right hand side there is a yellowgreen strap pull it and door will come open
Aug 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer GHW9150PWO Have F11 and DL errors. Have replaced the door lock 2 x and still have same error messages.
Well du is a door lock error but it can also mean an error with communication to the main control board or ccu. f11 is also a communication error in either the ccu or the mcu ( motor control board)......easiest thing to try is to unplug all your connections to the ccu and plug them back in and try it again.....sometimes a wire harness just may be loose....if that dosent work I would look at replacing the ccu ( central control unit )
Jul 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ghw9150pwo code
you got a door lock (dl ) issue, can be caused by a bad door lock, but can also be triggered by a baad CCU (located under main top assy.. might have also have a wiring problem leading to the lock assy "popped "off by chance.
Mar 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WM-2277HW Front Load Washer Logo
12 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
