Question about KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher
Kitchenaid 582-2 keeps shutting off 1 minute into the wash cycle and will not drain
rpbuice
  • 161 Answers
SOURCE: Kitchenaid dishwasher
Motor bad. If you are getting power to the motor then the motor is bad.
Posted on Dec 16, 2008
  • 6 Answers
SOURCE: Our Kitchenaid kuds25se fills with water but won't wash or drain.
i would check the check valve ....i had the same issue and the info within below link got be up and running again
http://fixitnow.com/wp/2008/11/14/older-whirlpool-kenmore-dishwasher-wont-drain/
Posted on Jun 25, 2009
  • 670 Answers
SOURCE: KitchenAid dishwasher allows water to drain while washing
Your dishwasher is siphoning the water out. The drain hose should turn upward, nearly to the bottom side of the counter top, before it attaches to the drain or disposal. If it has an independant drain it still needs the rise and also needs an air break to stop the siphoning.
Posted on Jul 18, 2009
Daniel S
  • 4323 Answers
SOURCE: KUDS30IXBL Kitchenaid dish washer was
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 17, 2011
mindreader
  • 578 Answers
SOURCE: KitchenAid KUDL021R dishwasher. Wash cycle goes for 1 hr. 22 mins. before changing to dry cycle. Is this normal?
Depends on setting. That machine uses very little water but does run longer to ensure that dishes are clean. Power usage is quite a bit higher. Try a short cycle setting.
Posted on Jan 06, 2012
Model number KUDS30IVBL0. When in the normal wash cycle the machine will go through the first wash cycle then drains. But the pump keeps running even after all the water has drained from the unit.
if you just let it go will pump shut off by itself after a few more minutes ?? or do you have to intervene as it will go that way all day long ?
Sep 02, 2015 | KitchenAid Dishwashers
I have a Kitchenaid dishwasher model KUDC10IXWH0 that has a problem. It will not complete the wash cycle. It runs for about 15 minute and then goes to cancel/drain cycle. The code on it is 6-1. Any...
Hello Carol;
My name is Peter. I am a retired field service appliance technician.
I am going to ask you to do a diagnostics and then get back to me.
Search:
4317364_kad-9_kitchenaid_drawer_dishwasher.pdf
Dec 23, 2014 | KitchenAid Dishwashers
How do I reset my KitchenAid Model KUDS35FXSS1
The unit normally has a 1:20 to 1:30 fill cycle with pauses in between while the wash motor starts and stops without running a diagnostic mode this normally happens when the control outputs power to the wash pump motor but the pump doesn't start
Sep 13, 2014 | KitchenAid Dishwashers
My 15 yr old Bosch d/w starts at 13 min & runs to 1, doesn't gets to CL. No water in or drain out.
IF IT ENDS UP WITH WATER SHOWING AT THE END OF EVERY WASH THEN THE DRAIN PUMP IS JAMMED OR FAILED THE DISHWASHER PROG WILL JUST KEEP LOOPING BACK TRYING TO DRAIN THE WATER.
Mar 04, 2017 | Bosch Dishwashers
KitchenAide washer keeps agitating in the rinse cycle-will not mo
It sounds like there is a dead spot in the timer. The timer is the control device behind the large knob on the right. The timer part number for you machine is 3955761 and runs about $150.00 for the part.
Apr 20, 2010 | KitchenAid KAWS850LE Top Load Washer
Jul 17, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
KitchenAid Washing machine stops mid-cycle and stays stopped
sounds like you need to replace your lid switch asssy part number 285671, unit not recognizing the door closed so for safetyreasons stops after first rinse and wont drain/spin. your tripping the switch by bangin on it
May 12, 2008 | KitchenAid KHWS01PWH Global Horizontal...
KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher Logo
195 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
