Question about Hoover Vacuums
I have a PAWS Windtunnel T Series vaccuum and the roller is not turning
The roller with the brushed is not turning. It will turn when i push the vaccuum because the brushes catch the carpet, but the vaccuum isn't turning the brushes to lift the dirt.
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
  • 4 Answers
SOURCE: brush won't turn while sweeping
Does it smell like anythings burning if it's on for a while?
It could be that the belt is just stretched out and not keeping enough tension on the brush while its on the carpet. Once you tilt the vacuum up, there's no more friction, so it spins freely. I've had a few that did that.
Posted on Oct 26, 2008
landsend
  • 1066 Answers
SOURCE: hoover windtunnel vacuum roller brush doesn't
does the motor turn?  if it does replace the belt.
Posted on Apr 04, 2009
SOURCE: brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
Posted on Jun 04, 2009
SOURCE: Carpet roller will not turn. Vacuum still sucks up dirt
It IS true that you can take the plastic cover off the top of the carpet head. But in addition to removing the two Phillips screws at the bottom, you have to manouver the wand release a bit. Loosen the screw and carefully pull the release back just as much as you need to, to remove the cover.
You will also need to pull manually release the four clips - two at the back and two on the sides - to pull the cover off.
However, I did all this and found that the plastic setting holding the roller canister in at one end had been burned out so that the roller didn't sit properly. Nothing I can do to fix it except order a replacement. The original problem was caused by getting carpet ends caught up in the roller. This caused the burning.
Posted on Sep 28, 2009
My hoover windtunnel upright self-propelled..seems the rollers are turned off. where is switch to turn them on?
The switch to turn the brush roll on and off is on the top cover of the nozzle housing
Jul 22, 2014 | Hoover Vacuums
Hoover windtunnel t series belt is loose- roller brush doesnt turn. Its brand new belt is slipping. we bough new belts and putthem on same problem. Can not find solutio in manual. Is the belt supposed to...
I also have a loose belt and have bought additional belts but have the same problem. I put the it around the metal rotor and around the brush roller a shown by he Hoover video, and it is loose.
Nov 28, 2010 | Hoover S3765-040 WindTunnel Bagless...
The roll brush will not turn when on floor. Too much pressure stops brush. Changed belts and still not working
Turn the belt inside out. This problem stems from a design flaw in the mechanism that turns the hoover from bare floor to carpet. After taking it apart I realized that the spring that pushes the belt tight (to make roller spin) is not any where near strong enough to keep the brush rolling. My solution was to turn the belt inside out (there by essentially shortening the belt and allowing enough pressure to be applied to the roller to keep it spinning. Horrible design flaw. I am an engineer and find this pathetic. Hope this helps someone.
Jan 22, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Just looking to see if worth repalce roller or
just look to see if you can get the rollers replaced.
Jul 02, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover U5468-900 WindTunnel Supreme suction is suddenly poor
The other possibility is there is a blockage in the foot. these models have dual channel air flow (windtunnel) and become blocked when not cleaned depending on use. under the roller there is a cavity that can be removed for cleaning. a hot motor can be caused by poor air flow.
Mar 15, 2009 | Hoover U5453-900 WindTunnel Supreme Bagged...
Automatic brush roller turned off
This model you will tilt forward and then change the carpet knob to bare floor
Feb 01, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush Roll belt won't engage on WindTunnel self-propelled
When you had the brush roll off, did the ends turn freely? If not then the brush won't turn and the belt will just slip. You would have to replace the brush roll if either of the ends are frozen. Other then that you would have to remove the top cover to see if there any broken parts, there is a spring loaded asm, it has a black wheel that will push the V belt when it is in the carpet setting and the handle is in the down position, it could be jammed so the roller is stuck.
Jul 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Jan 26, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
15 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
