Question about Toshiba 27A30 27" TV
WHERE CAN I BUY A REMOTE FOR TOSHIBA 27A30 ?
THE REMOTE THAT CAME WITH THE MODEL #27A30 IS NOT WORKING. I HAVE REPLACED THE BATTERIES TWICE AND STILL I CAN'T TURN THE TV ON AND OFF WITH THE REMOTE, I HAVE TO TURN IT ON AND OFF FROM THE SET ITSELF.
techman
  • 3130 Answers
SOURCE: Remote signals
If you tryed a universal remote , that remote should have at least worked the volume and the channels selector. It could be whats called a remote sensor assy thats mounted up toward the front of the set on the inside between the buttons. Its not really a user changeable part as there is soldering involved to replace the sensor. Realisticly, the correct way to trouble-shoot this set is to look at the data or logic line coming out of the remote sensor with an osilliscope to see the data and if it goes all the way to the microprocessor IC. If it does and no remote operation happens then the Micro's bad. Theres way to much Hi-voltage in these sets for a handi-person to tinker with, and its advised that a tech take a look at this set for you . Sorry I couldnbt be of more assistance. Good Luck
Posted on Jun 12, 2006
marked
  • 6487 Answers
SOURCE: power surge
Yes possibile there's some IC's that are burn inside it and also the power supply can be damage so resetting it will not do anything , if you can take it to a repair center and let them check this unit and fix it.
Good luck........
Posted on Aug 09, 2008
  • 13433 Answers
SOURCE: remote control not working
is the remote original and ment for the television? if not I would suggest a universal remote from any local retail shop to replace the non working remote.
Posted on Jan 02, 2009
cactus bob
  • 267 Answers
SOURCE: Toshiba 36HF73 tv with remote (CT-90047). Remote doesn't work.
you just may have a bad remote . remotes go bad in strange ways sometimes messing up a program for just the tv and all other things iits programed for are fine . the recever in the tv is rock solid i have NEVER had one go bad on a modern tv (tv made in the last 20 years) try a new remote and enjoy............. Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 26, 2009
  • 541 Answers
SOURCE: My remote control on my toshiba 32
A lot of times it is the remote sensor in the set. These are good sets so I would have it checked out. Could be fairly cheap. Thanks for using fixya.
Posted on Nov 09, 2009
Need remote code for toshiba 27A30 tv.
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web
There is no two digit codes for Toshiba.
Three digit codes are: 013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
Four digit codes and all about proceedings to synchronise it with TV can be had from the above site.
May 14, 2012 | Universal Remote Control DIRECTV Universal...
Flat screen toshiba tv black screenbut a sound
hello, usually in that case, the cause to the failure, is the inverter board. but first you have to chek the 24v that should be supplied to the inverter. if the voltage is ok. then you should replace the inverter board
May 20, 2011 | Toshiba 27A30 27" TV
The remote control stopped working on my toshiba flat screen i changed the batteries and only the volume works with the remote still can't turn on/off or change channels
Make sure the mode switch is set correctly for the device (TV, Cable, Video recorder, etc) that you are trying to control.
Apr 28, 2010 | Toshiba CZ36V61 TV
Toshiba Remote WC-FM2
Found a way to detect whether the light on the remote activates by viewing it through a camera lens. Problem solved.
Dec 29, 2009 | Toshiba WC-FM2 Remote Control
My universal remote stopped working, I bought another one and it doesn't work either, I mean it doesn't work with my set, it seems I programmed it correctly but when I try to change the channel it doesn't...
It was the TV set! I googled remote control problems and went on one of the websites......The answer was quite simple, unplug the TV for a few minutes and let it reset itself. I did and it did! I guess it's no different than a cell phone or computer sometimes!
Sep 16, 2009 | Toshiba 27A30 27" TV
Batteries changed sky + remote now does not work - TV Toshiba. Do I need a code to align my remote to my tv again?
Yes, very often after removing the batteries to replace them in a sky handset, you do need to re-code the hand set to your type of TV. Refer to your user guide for the code number for your type & model of TV.
Jul 22, 2009 | Sky ARF E- Belt CP Collective Pitch...
Toshiba remote stopped working
remotes run on infra red technology. that part of the remote could be damaged. if this is the case its just cheaper to get another remote. just remember if you get a universal one .. you keep the code book.
Apr 28, 2009 | Televison & Video
Amana Portable A/C Model#AP077R Remote control worked twice and then stopped working. Replaced batteries twice but no luck. Any suggestions?
I have a similar problem. The remote works for 5 to 10 minutes then no longer works. If I take the batteries out of the remote for 10 minutes (or longer) and reinstall them, the remote will again work for 5 to 10 minutes. I got a replacement remote from Frys and it behaved the same way.
Jul 06, 2008 | Heating & Cooling
Toshiba TV
Try unplugging the set for about 2 minutes to reset the TV. The other possibility is a stuck button on the TV or a remote control near the set that is randomly sending out signals.
Mar 25, 2007 | Toshiba 27A30 27" TV
Toshiba 27A30 that blows Fuse
Jeff, If your not a technician please dont mess with the set as you can get seriuoly hurt by experimenting. And replacing a fuse that is black is only going to blow again and possibly cause more problems and damage the set more then it already is. Your problem is a shorted B+ rectifier or a capacitor or voltage regulator IC. If you don,t know what this is, or you don't know how to solder, as well as unsolder, Please seek out a pro to assit you with this repair. Good Luck
Aug 06, 2006 | Toshiba 27A30 27" TV
Toshiba 27A30 27" TV Logo
13 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
