Question about Select Brands Washing Machines
Fernand alexandre poulin - Select Brands Washing Machines
How can I ascertain the value for my fernandes electric base guitar serial # 100995
Without a model number, I'd hazard a guess at around $250-$300, based on Craigslist and EBay pricing
Sep 15, 2014 | Music
How do i check to see if there is any line on my poulin weedeater
not sure what a poulin weedeater is doing in the website section. please repost in the correct section if you haven't done so already.
May 11, 2014 | Computers & Internet
I have several serial numbers of guns, and need to use those numbers to get the year they were made and what they are.
Hi cjre:
Check with the manufacturer for each gun to determine exactly what you have. Then you can search such sites as Shotgun News and Gunbroker.com to see what is out there. you could always seek the opinion of a gunsmith and/or gun dealer. if it an antique or collectible, check with firearm auctioneers such as Poulin Auctions and do a comparative search. poulin might be able to help you with a valuation.
good luck"
Lawrencevortac
Oct 08, 2012 | Refrigerators
I need a schematic drawing for a Poulan 445 PRO Chain Pole Saw
Go to this page:
http://www.jackssmallengines.com/help.cfm
Choose
1. Poulin
2. Poulin Pro
3. Pole Pruner
4. Gas
Then select either PP446E Type 1 or Type 2
If you need parts for the attachments then choose attachments and find yours.
This will get you straight to the engine:
http://www.jackssmallengines.com/help.cfm#AssemblyPartsSearch'model_3hfQcmydHGxAIk/GvlHpyA=='assembly_/GhQJfqNUvNbNmAjA03NAg=='brand_ahjxOQtsOoMBNqd6InjYkA==
Thanks for choosing FixYa.
Kelly
952-051549
Oct 02, 2010 | Garden
Installing recoil spring for Poulin P3314
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Oct 17, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
I need an intake for a poulin push mower with a
"Model-Type-Code" numbers on a Quantum Series are usually located on the sheet metal right above the muffler. If not there, remove the plastic cover from the blower housing and check on the blower housing near the spark plug wire.
Hope this helps
Oct 02, 2009 | Poulan "Poulan" Push Mower
MSI X340 built in cam troubles
Just hit the "function" key and "f6" togueder. It will install automatic and it will work just fine.
Alexandre David
Sep 29, 2009 | MSI Computers & Internet
Washing Machines Logo
18 people viewed this question
Top Select Brands Washing Machines Experts
Are you a Select Brands Washing Machine Expert? Answer questions, earn points and help others
