Question about Canon Eos Cameras
Canon Rebel EOS T3i - camera has power but there is no LCD display whatsoever.
HDMI works and linking with EOS Digial on Windows 7 works too. I tried all features in camera and still I have a black screen.
  • 26 Answers
SOURCE: canon eos digital canon rebel xti - LCD won't work when shooting
Most DSLR cameras (like your Canon) don't have a live view - in other words, you can't "see" the image before you capture it. You must use the viewfinder.
Posted on Dec 16, 2007
  • 7 Answers
SOURCE: Canon EOS/Rebel XT won't power up
Joe, this happened to me, just tonight... I got a new CF card and stuck it in, turned it on and one CF card flash. Completely dead from there. I found one of the CF card pins bent over, shorted out the socket and blew the mainboard fuse. I took the camera apart, found the fuse (labelled K) about under the set button area) I bridged the fuse with a bit of solder, straightened out the pin in the socket, put it all back together and it's working fine. The fuse is under the right side shield cover, it's labelled with a letter K. There is another fuse on the power inlet board (below the shutter button) and it's labelled 'P'...
Posted on Aug 22, 2009
  • 11967 Answers
SOURCE: Canon Rebel XS displays busy signal after I take a
Is your card nearly full? Is your battery fully charged?
Posted on Dec 19, 2009
pabloloco
  • 2335 Answers
SOURCE: Canon EOS - no data on LCD and viewfinder says busy
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Posted on Apr 15, 2010
  • 85 Answers
SOURCE: Blank screen on Canon Powershot S2is camera
hi.if you are telling both viewfinder and lcd are blank or black the problem is in the shutter that you found inside of the lens are not open.sometimes the cuase of the is humidity or moist goin inside of the shutter thats why it will not work properly or stuck up.if you can open your camera and adjust the shuuter from lens unit its better .but if not its better you bring to service center and request for adjustment.
by the way try also to reset your camera to default setting maybe it will help you.
thank you
Posted on Jul 08, 2010
Testimonial: "Thank you so much for taking the time to help me, i will try your suggestions tonight, really appreciate your help, thanks again"
I have a canon t3i. The menu doesn't turn on when you turn on the camera.
The menu doesn't display when you switch on. You should get the settings screen appear. Once powered up just hit the MENU button
Mar 02, 2015 | Canon EOS Rebel T3i 600D SLR Digital...
Tip
Canon Rebel XS Firmware Update WIN Models: Canon EOS Rebel XS / Canon EOS 1000D...
Solves: BUSY Error & Error 99
Does your Canon EOS Rebel XS / Canon EOS 1000D suffer from either of the following error messages that prevent it from normal operation?
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems.
To download the Windows version of the Canon EOS Rebel XS / Canon EOS 1000D firmware upgrade, click here.
I hope that helps.
__________________________
on Apr 15, 2010 | Canon EOS Rebel XS 35mm SLR Camera
LCD Screen won't turn on. I can take pictures just fine but the screen just won't turn on. Hasn't been dropped or exposed to water at all. Canon EOS Rebel T3i
There are a few thing you may want to look at. In your menu settings (the second little wrench icon) you will find the LCD on/off options: Shutter Btn, Shutter/Disp, and Remain on, select your desired setting (page 179 in the T3i manual) Check to see that the display is activated by the "DISP." button located just in front of the Mode Dial. For the display to remain on during shooting you must me in "live view" which is avctivated by the icon button located to the immediate right of the eye cup. Unless this "live View" option is selected the LCD will remain off to save power. Also, if the menu is not visible try activating the quick menu "Q" button located just below the apature "AV" button. The LCD should work in the play/review mode at all times, if that is not the case then maybe repairs are necessary.
You can view the manual from the link:
http://www.bhphotovideo.com/lit_files/16003.pdf
Mar 19, 2014 | Canon EOS 600D Rebel T3i Digital Camera
I have the Canon Rebel T3i and having troubles with the LCD monitor. When I turn the DSLR camera on, the camera works perfectly fine. I can take pictures and the camera itself works perfectly. The...
Possible dead LCD? try these
1.press the play button to see if you can view photos
2. press the "disp." button near the shutter
if these fail. send it back for warranty
Jul 04, 2011 | Canon EOS 600D Rebel T3i Digital Camera
I have purchased today an EOS Rebel Canon T3i camera and am trying to register it today to qualify for benefits. This product does not appear on your list. Please advise me what to do.
Register your camera directly with the manufacturer.
If you bought it in the US, go to http://www.canonusa.com
Under the "Consumer & Home Office Tab" select "Product Registration".
If you bought it elsewhere, go to http://www.canon.com
Select your country or region and go from there.
Apr 29, 2011 | Cameras
My Canon 1000D won't operate even when turned on. There is power somewhere because there is a lighted display in the viewfinder and it flashes busy
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
Apr 06, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
The metering screen inside the viewfinder keeps flashing BUSY, and the display screen will not show anything.(Canon Rebel XS Digital SLR)
I hope that helps.
Mar 01, 2010 | Canon EOS Rebel XSi Digital Camera
Camera will come on but the lcd wont when i try to take a pic it flashes a busy signal in the veiwfinder
I hope that helps.
Jan 24, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
The menu screen not working. Also, when i try to take photo it showing (busy). what shall i do???
I hope that helps.
Jan 07, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Rebel XS was working fine... yesterday, all of a sudden, the LCD screen went blank and it displays 'busy' when trying to take a picture. Recharging the battery and replacing the sd card didn't change...
I hope that helps.
Nov 30, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Cameras Logo
13 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
