Question about RCA HD61LPW163 61" Rear Projecection HDTV
RCA HD61LPW163 does not power up
My RCA HP61LPW163 is approximately 3 years old without any problems to date, with original bulb. I recently had a power outage while the tv was on. The power was out for approx. 3-4 minutes, and when power was restored, I was unable to get the tv to power up. Upon plugging in to the receptacle, I do hear a relay energize and then nothing but the power and control led's on front of set light up.
Thank you in advance for your help.
  • 790 Answers
Ok you have defective power oscillation circuit! maybe you have shorted parts. your TV needs to diagnose to qualified technician!
Posted on Oct 28, 2007
RCA M50WH72S Replaced bulb and ballast. TV comes on with good video for about 5 seconds, then off with good audio, front power light blinks 5 times. After a few minutes the video comes back on and repeats...
Check capacitors cp624, cp647 1000uf@35v each. They are in the power supply. Can be seen with bulge on the top. Seems to be a common problem with this model RCA.
Jun 07, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
I have an RCA M50WH72syx12, 50" DLP.
Yeah could be expensive if it isn't the lamp.
Mind you could be a little easier, might just be a fuse on the video relay. If you are confident in being able to open it up, check the relay that runs from the video input to the power capacitors and there should be a small fuse along that circuit.
If the fuse has a broken capsule then you may just be in luck. Failing finding a broken fuse, then I would agree with you on the bulb. But check the blub for any markings or cracks because they usually only make noise when the vacuum fails.
Hope this helps and good luck mate! :D
Nov 23, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
I've recently replaced the bulb, thinking it would solve it from turning off (powering down) every so often. Replacing the bulb slow the problem down, but as of late, the problem has worsened. I've also...
Ballast board it is what powers Lamp on and CK the Lamp Fan if it stops and is not keeping Lamp cool then set will shut off.Fans are not to stop running while set is turned ON. Encompass Parts Distrubtion
1-800-638-3328 they might have it in stock.
Feb 16, 2010 | Samsung HLN617W 61" Rear Projection HDTV
HD61LPW163 won't start after replacing the bulb
Hi I am Vortash before you go into the back you may find this is just as simple as pushing the Re- set button?.. the manual is available for this set ( same Chasis and interior workings ) under HD61LPW162 at ...
hope this is of help if you have any further problems just post on this page and I will be notified I will then download the service manual and talk you through any possibilities .. Regards Vortash
May 22, 2009 | RCA HD61LPW163 61" Rear Projecection HDTV
Hi I am vortash I have a number of these sets with faults on the go at the moment they seem to have a life of their own or not as the case may be ?. I have just downloaded the manual for this set and it has a fault finding section you might try it was from this may help I am unsure still looking for an actual schematic let me know how you get on
Regards Vortash
Dec 16, 2008 | RCA HD61LPW163 61" Rear Projecection HDTV
I have a GE side by side refrigerator model # PSS26SGRD and the water and ice dispenser stops working without any warning or symptom intermintently. It will be working find for days or weeks and suddenly...
Well, the solution to this problem was posted in this thread
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
Dec 07, 2008 | GE Profile¿ 26.5 Cu. Ft. Stainless...
KDF-E50A10 - TV keeps turning off and on
It sounds like it is just the lamp, be sure to replace it with an original Sony lamp, the replacements are unreliable
Sep 28, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Rca model# hd61lpw163
while having another problem fixed the tech told us about fixing the shadow in the corner problem. check the tubes. he said when they get hot the glue around the tube melts and causes the problem. he removed the access glue and ours is all better, i hope this works for you too.
Jul 11, 2008 | RCA HD61LPW163 61" Rear Projecection HDTV
RCA HD61LPW163 61" Rear Projecection HDTV Logo
63 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
