Question about Sharp LC-20SH3U 20 in. EDTV-Ready LCD Television
Switch form cable to antenna
I have no remote and need to switch from analog to digital
4 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: TV somehow switched to analog even though it is a
It most likely has the capability to tune analog stations in as well. To get to a digital station you should just have to punch the numbers in on the remote IE: 5-1 or 5.1
Posted on Oct 17, 2009
  • 8457 Answers
SOURCE: analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Posted on Jan 16, 2010
  • 11800 Answers
SOURCE: How do I switch my TV from analog to digital? And
If you have a cable box then you don't do the switch in the tv, you do it in the box. If the box isn't a digital model then you must replace it.
BTW the digital channels operate on the same frequencies as the normal ones, to find them just do a channel scan.
Posted on Aug 20, 2010
Analog to digital
If this is an older standard tv it is analog only it's not capable of processing digital tv transmissions in any way by itself you will need a digital tv converter box. thats true for antenna reception or cable systems that supply a digital signal,with digital cable systems you will probably need their digital converter box over the air & digital cable converters are not compatable with each other.
Apr 11, 2014 | Televison & Video
Need want to use tv with antenna indoor and what remote would i need
You would first need to plug the antenna into a digital box to change the analog signal to a digital signal, then run the cable out of the digital box to the back of your TV; you should then be able to use the TV's remote (unless of course the digital box comes with its own remote).
Feb 19, 2014 | Emerson EWF2006 TV
Jvc hd56g786 channels stuck on digital cant get them changed to analog
Using the television's remote control, enter the user's menu. Search for video input and change from cable to antenna. If still experiencing difficulty, visit the JVC website and download the owner's manual to learn the procedure of changing the video input type and deactivate the television's digital decoder.
Dec 22, 2013 | JVC Televison & Video
Video matrix switch uninitialized?
Use a Hyper terminal, Hercules SETUP utility is user friendly for this. Attach a Serial cable to the unit (straight through cable not null modem) or use a USB to serial cable.
Set the Baud rate to 115200
Data size 8
Parity none
Handshake OFF
Mode Free
do not check the box for Hex
For the 12x8 digital/ analog audio matrix switch cat5 enter the command [S,M,Q]
12x8 digital/ analog audio matrix switch [S,M,L]
8x8 component video digital/ analog audio matrix switch cat5 [S,M,C]
8x8 component video digital/ analog audio matrix switch [S,M,B8]
12x8 component video matrix switch [S,M,I]
12x8 component video matrix switch cat5 [S,M,H]
8x16 digital/ analog audio matrix switch [S,M,G]
8x16 digital/ analog audio matrix switch cat5 [S,M,E]
8x16 component video matrix switch [S,M,F]
8x16 component video matrix switch cat5 [S,M,D]
12x16 component video matrix switch [S,M,J]
12x16 component video matrix switch cat5 [S,M,O]
12x16 digital/ analog audio matrix switch [S,M,K]
12x16 digital/ analog audio matrix switch cat5 [S,M,R]
Oct 31, 2013 | HDTV Supply 12x8 stackable digital/analog...
Indoor antenna won't work on my cable ready set
You do have to make sure to switch the settings to an external antenna. You also will have to check that you have what is an analog signal available to you. If you antenna is analog it will only get analog broadcast. You may also need to switch to a digital tv antenna, The other thing is the range of you antenna. Most indoors, in a congested area will only pull in signal from about 20 to 25 miles out.
Jun 18, 2013 | RCA Ant121 Indoor Passive Antenna
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
Sep 06, 2011 | Hitachi 65F59 65" HDTV
Hello, I am currently having a problem with my Audiosonic KM0767 Standard Definition Set Top Box. When we first bought it we wired up all the plugs and it worked great. We then moved onto Foxtel...
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
Dec 26, 2010 | Televison & Video
Digital TV flunked the digital test
you will most likely need a box to convert the signal from the antenna to digital . the problem is the signal not the tv
Dec 14, 2008 | Sylvania LC370SL8 37 in. LCD Television
Have a problem
Currently, your switch box likely has several inputs, which as you said are occupied by your DVD Player, XBOX, and your television source. The output of the switch is then fed to your TV.
What you will need to do is insert the DTV converter box BEFORE the switch box. If you have an analog antenna on your TV (rabbit ears) you will need to put the converter box between your antenna and the switch box (the cables, not the box itself) so that your wiring goes like this:
Antenna ---- converter box ---- Switch box
XBOX ---------------------------------switch box
DVD -----------------------------------switch box
And the switch box still goes to the TV. However, you do not NEED to use the converter box until February of 2009.
Jun 11, 2008 | Insignia Digital-to-Analog Converter for...
Sharp LC-20SH3U 20 in. EDTV-Ready LCD Television Logo
37 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
