Question about Dell XPS 8500 X8500-4726BK Desktop PC Windows 7 Home Premium 64-Bit
Xps 8500 turns on and off no display
When power on, I hear ventilation system coming up, then beep and pc turns off. No boot and no display at all. ? Harddisk defect ? Regards Tommy
dragon_rag27
  • 89 Answers
SOURCE: Dell XPS fan come on but nothing else powers up.
most likly a hardware issue i would recomend taking it into a shop what is your computer experience?
Posted on Jan 08, 2009
knotbeerdan
  • 413 Answers
SOURCE: XPS 600 - Six Beeps No Boot
Follow this link and figure out what the beep code is telling you and i can try to help you fix it from there. I can tell you that what you are describing usually is caused by a hardware issue.
http://www.computerhope.com/beep.htm
Posted on Jan 22, 2009
  • 1019 Answers
SOURCE: Dell Dimension XPS PC Desktop won't boot
Vista is available in 32 and 64 bit os.
if your system ran xp which was most likely 32 bit. And you have installed a 64 bit version os.
this will be your problem, also Vista requires more system RAM/Memory to run it.
If you get 1 beep at startup, it states the system is ok.
Alternatives are device drivers incompatability.
Check M$ website, regarding vistas minimum system requirements.
Mike @ Compurepair.
Posted on Jun 11, 2009
wildbear6
  • 192 Answers
SOURCE: My xps 420 pc desktop wont boot. Shut it down last
Try and reset your CMOS and see if it helps.
If you're not sure how, then unplug the power cable from your PC, then take off the side panel, on the motherboard is a set of 2 or 3 pins to Clear the CMOS (reset the BIOS) all boards are different, so there is no set location for the CMOS pins, if you're unsure, just remove the battery from the motherboard for about 30 seconds, then replace it ("+" facing up)
But you need to make sure your PS is not plugged into any external power source while you're doing this or you risk deleting your BIOS
Hope this helps in some way.
Posted on Jan 01, 2010
drifterK
  • 4924 Answers
SOURCE: dell gx 520 long beeps and unable boot display?What's your problem?
Usually the beeps ore associated with ram memory failure ..or video card not being well plugged or being faulty ..To stat check the ram memory ..Just remove them all ..(if you have more modules) ..and after that insert one by one and try to boot ..If it still makes the same noise (beep ) and each one ..it means the ram is ok ..and the fault from other way ..If it starts with only one one ..it means the other is faulty ..Anyway ..usually the ram memory does not damage itself ..but most likely does not make contact well ..so plug them well back in the slot and try again ..
If it always make that beep ..try to see if you have a pci or agp or video card ..and if you do ..remove the card and post it back ..Usually if you remove it and you have a on board card ..you can already boot up if the card is faulty ..and use the card on board until you get another card ..
(the idea is that for the ram fault the beep is short and in some kinda loop ..but if it starts the fan and keep beeping it is the video card to blame .It is either out of slot and does not making contact well or is damaged and need to be replaced.
Posted on Dec 26, 2011
Alert. previous attempts at booting this systemhave failed at checkpoint [0032]
XPS 8500 Desktop booting fails - General Hardware - Desktop - Dell ...
en.community.dell.com/support-forums/desktop/f/3514/.../19452875
Dell
Jun 13, 2012 - 16 posts - ‎9 authors
I am sorry to know the concern with the computer. As you .... I have the identical problem on a 3 week old XPS 8500 desktop machine. It seems ... Dell XPS 8500 - Will Not Boot At All - Motherboard ...
Aug 13, 2014
Dell XPS 8500 Unable To Boot
Jun 25, 2013
New Dell XPS 8500 won't boot
Dec 5, 2012
XPS 8500 UEFI boot
Oct 29, 2012
More results from en.community.dell.com
How to Use and Troubleshoot the XPS 8500 ' Dell US
Dec 15, 2015 | Dell XPS 8500 Desktop Computer; Intel Core...
Why doesn't my Dell XPS 8500 boot up?
hold the power button in for a count of 8 and it should shut all the way down. Then try and turn it back on
If it still does not boot, do you still have a warranty? Could be motherboard gone bad. Usually if it is memory or video your will hear beeps
Aug 05, 2014 | Microsoft Windows XP Home Edition
Xps 8500 beep
Try removing the RAM sticks and rebooting.
Dec 15, 2013 | Dell, Inc Dell XPS 8500
Beep codes on dell xps one 2010
If I understand your issue, it sounds like the display works fine until it loads Windows, and then it has the error? It sounds to me like the video card drivers are crashing. This may be the case if you have recently updated them, or installed a new video card. I would recommend getting the latest drivers from the manufacturer's website on a CD, SD card, or USB drive, and then boot your computer in safe mode. Once in safe mode, install the new drivers, and see if that will help. You could also try using your onboard (integrated) video card if your motherboard has one. This could help rule out if the monitor is at fault. Just make sure your BIOS has the integrated card as a secondary video device if it the (I'm assuming PCIex16) peripheral card isn't found.
Oct 06, 2012 | Dell XPS One All-in-One TV Desktop with...
Dell xps laptop lcd screen black
If you have an external monitor, try connecting the laptop to it, then toggle FN+F8 to project display from lalaptop to external monitor.
If the external monitor does not have a display aswell (totally blank) , then its a problem with the video card.
You can also run an LCD Bist test by turning off the system , then while the system is turned off press D + power , If you dont hear a beep but no display at all, then its an LCD problem.
Hope this helps
Thanks
Dennis
Oct 18, 2011 | Dell XPS M1210 Notebook
There is a green blinking LED on my motherboard, and my computer is not turning on. What is wrong? Someone told me to check page 64 of a Dell .pdf file, and all it did was show me a layout of the...
John, pull the power cord and leave the system off for 30seconds. Then reconnect and attempt to power on the system. If it still doesn't boot then listen to hear if there are error beeps. The number of beeps indicate what the possible problem could be. You would check this is the troubleshooting section. -Ravi Shanghavi
Aug 19, 2010 | Dell XPS 200 PC Desktop
On startup it beeps and wont startup. i hit F12 and it works fine now. thats all i did. so what could be the problem? i've already replaced a power supply about a year ago. and also my dvd player is kinda...
On startup beep how many beep do you hear?
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Hope it Help you out ^_^
Jun 29, 2009 | Dell XPS 200 PC Desktop
Mike @ Compurepair.
Jun 11, 2009 | Dell Dimension XPS PC Desktop
Jan 22, 2009 | Dell XPS™ 600 PC Desktop
Dell XPS 8500 X8500-4726BK Desktop PC Windows 7 Home Premium 64-Bit Logo
19 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
