Question about Westinghouse Washing Machines
No agitation on westinghouse lt955s - Westinghouse Washing Machines
4 Suggested Answers
  • 5 Answers
SOURCE: have a westinghouse washer LT955s
I have had great luck with repairclinic.com. they will help diagnose and let you know what part you need and have them in stock. Also try Fox appliances, they have a great network and broad parts selection.
Posted on Jul 09, 2008
  • 6277 Answers
SOURCE: i am looking for a
Hi from retired Englishman in SW France, You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Posted on Mar 30, 2011
joeguest2
  • 2080 Answers
SOURCE: after the manual for my westinghouse washing
First of all...Thank you very much for choosing FixYa for your technical supports needs.
Here is a link to an online electronic copy of the OWNER'S GUIDE for your machine:
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134670300een.pdf
And here is a link to the INSTALLATION GUIDE which may also be helpful to you:
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134771500ef.pdf
And here is a link to the actual OPERATING INSTRUCTIONS for that machine:
http://manuals.frigidaire.com/prodinfo_pdf/Webster/1319276ef.pdf
To view the Owner's Guide or Operating Instructions just use your mouse to click on the corresponding links, which are the underlined and blue highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
Now, in order to remove the agitator you should first of all unplug the power cord to the unit as a safety precaution.
Next you will have to carefully pry open and lift off the small plastic cap which is on the very top of the agitator center column. Removing this cap exposes the main hold down bolt located inside the agitator column itself.
Now just use an extended socket wrench to unscrew the single securing bolt and then remove it. After that, the entire agitator should lift straight up and right out.
Here are some links to exploded view parts diagrams and parts list for that model showing how the agitator is secured. See parts 54-57 on the following diagram and parts list:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=1267937&pkw_=basket&model_id=5157990&NewWindow=1
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5157990&diagram_id=1267937#d1267937
Please COMMENT back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
If you are having difficulties locating your original question page with the solution I posted there, then plaese use the small blu COMMENT button just under this text to add a short comment here and let me know. I can then provide whatever assistance you need to navigate back to that page.
Thanks again.
Joe.
Posted on Oct 07, 2011
WHAT is causing my Westinghouse Top Loader Washing Machine model LT809S to only agitate in one direction ??
problem with the direction control relay or power board
call a technician to diagnose properly
Jul 21, 2015 | Westinghouse Washing Machines
After the manual for my westinghouse washing machine model no LT955S
Thanks again.
Joe.
Oct 01, 2011 | Westinghouse WWS833ES Super Capacity Top...
My Westinghouse lt908s washing machine has started bundling clothes up and knocking sides of machine. Even after opening lid and redistributing load evenly it keeps spinning then bundles up load and knocks...
May be a problem with agitator gear box,open on wash cycle and use screwdriver to by pass cut off switch by pushing screwdriver down on little switch that is located where tab on lid is.If agitator is traveling at too much of a rotation that may be cause,also agitator mat be lose if you can grab and move up and down.Then remove cap on top of agitator and tighten bolt,if lose if not agitator may need to be replaced!
Jun 12, 2011 | Westinghouse Washing Machines
I am looking for a WESTINGHOUSE WASHING MACHINE manual LT955S to download
Good luck,
John C.
Mar 30, 2011 | Washing Machines
I have a westinghouse lt955s. The machine is stopping while it is draining and on the display it keeps on flashing LD and the number of minutes left of the cycle. Does anyone know what LD means?
Ld = all water level lisghts flashing slowly accompanied by 5 fast beeps every 4 minutes - LID is open position
got this out of machine manual hope it helps
Oct 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
Westinghouse LT955s Washing Machine
Its the water solenoid. Is it where the hot and cold water connect? Check that the connection is tight and there is a rubber washer inside the hose fitting.
If this is inside the washing machine and not where the water connects to the machine as above, it sounds more like the water pump.
A photo would really help.
Aug 22, 2009 | Washing Machines
Have a westinghouse washer LT955s 9.5kg I am after a control card for it, electronic type. and price?
Jul 09, 2008 | Westinghouse Washing Machines
Removing agitator
Sorry, I can't help you. This is the area for asking questions about computer monitors, not washing machines. You clicked the wrong link.
Look at the top of the page, click the Westinghouse link and then on washing machine. Enter your question there.
Mar 28, 2008 | Westinghouse L1975NW Monitor
Washing Machines Logo
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Robert Siegel
Level 1 Expert
Steven Clarke
Steven Clarke
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
