How to add contact to speed dial - Computers & Internet
How to assign speed dial numbers
hold the preferred number to which you want to assign the contact to and press the assign contact or add contact option
Jul 15, 2015 | Cell Phones
How do you put speed dialing in a samsung GT-C3520
To Set speed dial numbers do the following:
1. In Menu mode, select Phonebook.
2. Select a contact to assign.
3. Select More -> Add to speed dial.
4. Select a number (if necessary).
5. Select a speed dial number you want to set.
The contact is saved to the speed dial number.
Note:
• You can call this contact by touching and
holding the assigned speed dial number in
the dialling screen.
• The first 3 speed dial numbers will be
assigned to the top 3 list on the widget toolbar.
May 16, 2014 | Samsung GT-C3520 Unlocked Quad-Band GSM...
Set speed dial
just open ur phone book,,der ul find ''CONTACTS '' followed by''down arrow'' drag dat arrow n ul find ''FAVORITES''click on dat n den add speed dials
Feb 21, 2012 | Samsung Cell Phones
How do you set up speed dial on the LG OPTIMUS cell phone?
From the LG Optimus S Manual:
Assigning Direct Dialing Numbers
Speed dialing, as available in other feature phones, is
not available. However, you are able to directly save a
contact to your Home screen.
To set a contact as Direct dial:
1. Press (Home Key) >(Menu Key) > Add > Shortcuts > Direct dial.
2. Tap a contact from your Contact List. The contact
will be shown on the Home screen.
Direct Dial-
Simply tap the contact on the Home screen.
Jan 04, 2011 | LG Cell Phones
How to enter a "speed dial number / name
Step 1Tap Start, and then tap Contacts.
Step 2Scroll to the contact for which you want to set up a speed dial number and press ENTER.
Step 3If you have entered more than one phone number for the contact, scroll to the phone number for which you want to add a speed dial number.
Step 4Tap Menu, and then tap Add to Speed Dial.
Step 5In the Location field, scroll up or down to select a keypad number. (Optional: If you skip this step, the device will assign a keypad number automatically.)
Step 6Tap OK.
Good luck.
Aug 31, 2010 | Panasonic KX TC1743B Cordless Phone
How do I enter numbers/use the speed dial? Any Manuals available?
when you want to enter a number on a speed dial you first want to go on the page with your contacts (where its has all the options : groups, contacts, new contact, etc...) look down the list and you will find "SPEED DIALS" click on that then numbers will apear 1-*lets say* 999 click on the first empty one and it will let you add a number or contact that you type in or choose. Then when you want to use the speed dial to call lets say "George" and he is your speed dial 1 just type in the number 1 as if you were typing in a phone number and his name will come up on the top of the screen or such and you just have to press call, or you can hold the one down and it will imidietly call "George"
Apr 27, 2010 | Lands Phones
How do I load contacts into speed dial and get them to work?Went by book ,pg. 14.When I try to speed dial it says not on list.
Go into you contact list and highlight the contact you want to add to you speed dial. Press the menu key and scroll down to the "add to speed dial" option and select it. The phone wil then ask you to select which number you would like to assigin that contact to. Once you have selected the number you want press the red end key to exit out and test it by holding the number you assigned that contact to down till it calls that person.
Feb 03, 2010 | Motorola Mobility Karma QA1 Cell Phone
USING SPEED DIAL ON SAMSUNG I600
Hi Linesh
Just had a look through the i600 manual and this is how you save a speed dial:
1. On the Home screen, press the Contacts soft key. You
can also press the Start soft key and select Contacts.
2. Select a contact from the list.
3. Scroll to a number, e-mail address, or web page
address.
4. Press the Menu soft key and select Add to Speed Dial.
5. If necessary, enter the name you want.
6. In the Keypad assignment field, select a location.
7. Press the Done soft key
Hope this helps.
Feb 15, 2008 | Samsung SCH-i600
Speed dial
Scroll to the name you want to put in speed dial. OPTIONS tab then DETAILS....then scroll down to ADD TO SPEED DIAL then it will prompt you Yes or No? click on YES..then pick a position and SELECT
Dec 05, 2007 | Cell Phones
Computers & Internet Logo
David Payne
David Payne
