Question about GE Monogram ZDP48L4GHSS Dual Fuel (Electric and Gas) Kitchen Range
GE monogram duel range gas code F9 while cleaning oven
ngafm
  • 166 Answers
SOURCE: GE Profile gas range
hello dreeden5
Ngafm at your service,
You have a GE Profile oven range. I and you just cleaned it and the pilot light on all four burners continues to click on and off.
It sounds like the gas line or the gas valve, have some debris in them!
They need to be evacuated by an experienced tech.
This time you need service.
Bless You ngafm
Please give me a good rating at this sight before you leave!
Thank You
Posted on Sep 11, 2008
  • 3 Answers
SOURCE: Oven wont light
Mine did that and I found the ignitor for the oven was bad. It was the "glow" type for pilotless ignition and it was burned out. It is supposed to glow bright red and the gas comes on and the oven will light. It was easy to tell that it was bad. But to check it I swapped the broiler ignitor with the oven ignitor and the oven worked.
Posted on Dec 20, 2008
SOURCE: How do I clean a GE gas range (self-cleaning oven?)
What do i clean the burners with ? the round surfers is harder to scrub, what do you advice .
Posted on Jun 22, 2009
jumptrout51
  • 3361 Answers
SOURCE: GE Self Cleaning Gas Range F2 Error, happens at
Your oven temperature sensor must be replaced. It is located in the oven compartment up high, may be right or left side depending on model. Smaller than a pencil about 3&1/2 inches long.
Posted on Jul 25, 2009
SOURCE: tin foil stuck to bottom of new ge monogram oven
I had the same thing just occur. GE is now telling me the only fix is to buy a new range. Great. $10K for a range that I use once.
Posted on Jun 10, 2010
GE monogram double oven . Self cleaning top oven and F9 in red showing and beeping noise
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Jul 17, 2016 | GE Monogram ZET3058SHSS Stainless Steel...
What does F9 mean
Failure to clean code
I have two Monogram ovens but they are not adjacent to each other top and bottom but are separate in different areas of the counter. I did the self clean for both ovens for the first time and one oven had the F9 error code about 1 hour and 45 min into the clean and the other did not sound a code.
Jan 24, 2011 | GE Monogram ZET3058SHSS Stainless Steel...
I have a 48" GE Monogram 4 burner with griddle gas/ duel fuel range (ZDP48N4GD1SS) that was set up for natural gas. I need to convert it to LP but the parts website doesn't show a conversion kit for this...
I just bought a new/used GE mongram natural gas range and need an LP conversion kit. Called GE and found them very UNhelpful. Can this be this hard? The party I called will not take the range back. $3000! I thought I got a great deal and cannot use the range the way it is. I need help too.
Aug 19, 2010 | GE Monogram ZDP48N4GHSS Stainless Steel...
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
Tin foil stuck to bottom of new ge monogram oven
Jan 04, 2009 | GE Monogram ZDP48L4GHSS Dual Fuel...
Need a duel fuel range
We love ours have had it for two years. We have the 48" Dual fuel with the grill on top. Model ZDP48N6RH2SS.
The only issue we had to adjust to is the btu's (stove top flame) are so high and there is designated simmer burner or low btu burner.
The grill is excellent especially in the winter but you have to follow the instructions. First time use we didn't let it heat up long enough. Patience - it's worth it.
That's for our model from 2006.
YOu must be sure to get a strong enough range hood for the range you buy.
Dec 24, 2008 | GE Monogram ZDP48L4GHSS Dual Fuel...
Error code f9 on self cleaning range.
I get a f9 message when I turn my oven onto clean and then it shuts off and goes to clock...what's the problem
Oct 01, 2008 | Frigidaire PLEF398AC Electric Kitchen...
GE Monogram ZDP48L4GHSS Dual Fuel (Electric and Gas) Kitchen Range Logo
29 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
