Question about Texas Instruments Baii Plus Financial Calculator With Case
How do i calc pv of for year 3-16?
I need to find out how to calculate pv for year 3-16.
How to calculate the cost of equity
final value = principal value x (1+I)^n
I= interest rate for n say 10% it would be 0.10
if n= 1 year then interest rate if
one year interest rate so if 5 years n= 5
if interest rate is monthly then divide year int rate by 12
and increase n by 12 so 5 years equals 60 terms of interest calculation.
cost of equity would be pv + pv * CPI
if CPi was 2.5% as an example
cost of equity for year one= PV + (PV * 2.5/100)
fv = pv*(1+2.5/100)^1
if cpi is different each year then
fv= pv1(1+2.5/100)^1 + pv1(1+cpi2/100)^1 + pv1(1+cpi3/100)^1
If CPI is same for each year then FV = PV (1+0.025)^number of years.
^ 2 is like squared
Jul 20, 2016 | Furniture
How do i calculate interest on a R20000.00 loan at 13% for 5 years on teh sharp el738f calculator
First make sure all previous amounts stored are cleared by pressing 2nd F MODE.
Then type in the original value 20 000 and press PV.
Type in the interest 13 and press I/Y.
(If i assume that the interest is compounded yearly my calculation is more simple)
press 5 and N
Press COMP FV and your answer will be - 36 848.70
(If I assume that the interest is compounded monthly, i need to input a little bit more data into my calculator)
Press 2nd F I/Y (to get to payments per year) and press 12 and ENT. Press ON.
Then press 5 and 2nd F N and then press N again.
Now calculate FV by pressing COMP FV which should give you - 38 177.13.
Take this value and subtract the PV from it to get the amount of interest earned.
May 16, 2014 | Sharp EL-738 Scientific Calculator
I am trying to do a financial calculation using a casio fx-83es calculator. The calc is to do with average rate of return each year. the calc is 5 square root symbol 1.734= 1.1164? How do I calculate
You should be careful with the symbols you are using. Roots are different. When you say `5 square root symbol 1.734` you are in fact doing the following: 5x square root(1.734) which is 6.5850.
What you need to do is extract the fifth root of 1.734.
The key to use to extract a root of index n (in your case 5) is to press the digit key for the index, then press [2nd][Y^x]. On the calculator near the [y^x] key you can see xRoot. This is the universal root key.
Jul 16, 2012 | Casio Office Equipment & Supplies
I am trying to calculate the number of periods - solve for the unknown number of years PV 625 interest 8% fv 1284 how do I calculate using the calculator
2nd [CLR TVM] (clear old data)
6 2 5 PV (present value)
8 I/Y (annual interest)
1 2 8 4 +/- FV (future value)
CPT N / 1 2 = (compute number of months, divide by 12 to get number of years)
Oct 15, 2010 | Texas Instruments BA-II Plus Calculator
Calc will not return a value im looking for when entering N,PV,FV
Having gone over a month without a response, I assume this is no longer a problem.
Apr 12, 2010 | Texas Instruments TI-89 Calculator
Lost CALCULATOR application
  • Scientific
  • Statistical
  • Financial
  • Programmable
  • Graphing
  • Complex arithmetic
  • Matrix/vector arithmetic
  • Unit arithmetic
  • RPN
Download You can download Calc into your phone or MIDP device using one of these links:
Calculator 1
http://midp-calc.sf.net/Calc.jad, or
http://midp-calc.sf.net/Calc.jar
click her for calculator 2
transfer both the files to your mobile and then install them by just clicking on open install
Mar 31, 2010 | Nokia 5220 XpressMusic Cellular Phone
Calculating PV where n=5; i=6%; $18,400=pmt; 0=FV.
Check to make sure you have the proper value set for payments-per-year.
Mar 27, 2009 | Texas Instruments BA-II Plus Calculator
PV and FV problem, result not like in manual
You have the payments-per-year set to 12. For this pair of problems, it needs to be set to 1.
Press 2nd [P/Y] 1 ENTER.
Jun 24, 2008 | Texas Instruments BA-II Plus Calculator
Getting wrong PV
PV=1,077,202 while FV=1,000,000 ? I wonder somebody will lent me $1,077,202 and accept to get back $1,000,000 in 10 years later.
Your example's got prob, guy !
Jun 10, 2008 | Texas Instruments BA-II Plus Calculator
PV FUNCTION GIVING WRONG ANSWERS
The BAII Plus comes from the factory set to assume monthly compounding. To fix this problem press 2nd then I/Y and enter 1 when prompted.
Sep 30, 2007 | Texas Instruments BA-II Plus Calculator
Texas Instruments Baii Plus Financial Calculator With Case Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
