Question about Mitsubishi WD-60638 DLP TV
My WD-60638 turns off right after i turn it on.
I have replaced the lamp because it blewout and not it will not stay on. When I turn it on it stays on for 30 seconds and then you can hear the fans turning off then the TV shuts down.
  • 1153 Answers
SOURCE: Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Posted on Sep 18, 2007
  • 38 Answers
SOURCE: mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Posted on Dec 24, 2008
rob52078
  • 40 Answers
SOURCE: When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Posted on Mar 13, 2009
  • 16 Answers
SOURCE: WD-52525 - No picture, green status light then turns to red lamp
check the lamp
Posted on Jun 26, 2009
  • 3 Answers
SOURCE: My tv mitsubishi wd-60735 turns
Don't know if this applys to you but if you have purchased anything but Osram or Philips replacement lamp for your DLP tv then this is probably your problem.. The generic is VERY tempting in this recession but in this case generic is poison to your dlp tv... i have a Mitsubishi 60735 and went thru 2 generic bulbs when my tv kept shutting down on it's own and the lights on front would flash, i could cut it back on for 10 minutes then flicker and shut down again ..well since the bulb was new i thought it may be defective so i got is exchanged for another one ... after all of the post i have seen how much repairs were going to cost on dlp sets no matter what the problem was ..i was ready to chunk the tv out the door when the second lamp was doing the same thing.....!! well a last ditch effort to save my tv before i trashed it or taking it apart to dissect it.. was to buy a brandname lamp ... in my case i purchased a Philips ..it cost twice as much =/ ..i could just return it if it didn't work.. well it was the generic lamps that was causing trouble.. the brandname worked perfectly .. i am just glad the generic lamp didn't do any damage to my TV!!! I have done further research on the generic lamps and realized that the damage it could have done was not worth the money i saved when i purchesed it... Generic is a great deal In some cases (household cleaners, etc..) but in this case GET THE NAME BRAND!!!! the only name brands i know of for these lamps are Philips or Osram/Sylvania.. hope this helps others from this headache. Do your research don't by generic lamp replacements, your DLP set cost to much to risk it.
Posted on Feb 16, 2012
My tv wont turn on
If you used a generic or neolux lamp--this could happen, Mits do NOT like them. use a Phillips bulb !!
Mar 31, 2014 | Mitsubishi WD Televison & Video
Replaced lamp
When you replaced the lamp did you reinstall the cover correctly?
There is a safety switch incorporated in the cover .
Mitsubishi WD-60638 firmware
Make sure software was in top menu in USB stick. Not ib a folder. Try reset buttons on front of TV. Could be bad e2p module. (boot firmware.)
Mar 30, 2014 | Mitsubishi WD-60638 DLP TV
Red statis light on
replace lamp if lamp is ok replace color wheel
Jul 11, 2013 | Mitsubishi WD-60638 DLP TV
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
I had to replace my lamp bulb in my mitsubishi wd-60638 tv and now i have a picture again but it is fickering and greenish tint to the screen
If you tried a cheap bulb then that might be the problem as some of the bulb carrage may not be complete4lyto spec. I had one that was close but there was a gap between bulb and where it fits. I went with a bulb dealer that had I believe a 1 year warrante and I have had no problems. I had a 73838 tv set.
Jul 26, 2017 | Mitsubishi WD-60638 DLP TV
Replaced lamp in my mitsubishi wd 60638 dlp but now I have a flickering picture
Sounds like a new lamp that is generic (not Mitsubishi) as the set does not know which lamp is in the set--works with one and not the other you have found your problem.
May 23, 2012 | Mitsubishi WD-60638 DLP TV
Mitsubishi WD-60638 DLP TV Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
