Need change batterie in a soundmate siren made by remington
How to reset the alarm siren after changing the battery?
It would be a good idea to have it scanned at the dealer because some can have sensors inside the door and at the roof area and all around the car because it is a theft alarm...,They can be a difficult project !!!!! If you KNOW everything is well connected and was replaced correctly The system should reset itself each time the battery is reconnected......Save time and have the alarm system scanned..
Dec 03, 2014 | Cars & Trucks
Alarm seems to work; been checked at Toyota but they say siren is broken and say it's a common fault. But everything else seems to work - you can hear the relay clicking; lights flash.
What is actually the problem, "Actually seems to work", what doesn't work.
If Toyota are on about the 9volt battery back up siren then the main siren may be working fine, but that might not be. Most cars especially Vauxhalls have a 9volt battery back up siren, so if someone tries stealing you motor and they disconnect the battery the 9volt battery will keep the siren going off.
Feb 19, 2011 | 1998 Toyota Corolla
My 2004 volvo xc90 says alarm system service required. any ideas on how to diagnose or any common problems
I had the same problem on my 04 XC90 - apparently it is a common failure... You need to replace a Siren module.
Oct 09, 2010 | 2004 Volvo XC90
Alarm goes off on its own..2001 Harley FatBoy
if you have the siren added to the system, there is a special 9volt battery in side the siren unit and it has reached its usable life and needs replacing. if you do not have a siren replace the batteries in the key fobs low voltage on them can also cause a problem.
Sep 10, 2010 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
How to turn off the alarm,, Changed the battery now the alarm will not go off on my 2001 XG300.
Do you still have your Key Fob? The siren is impossible to turn off without the Key Fob.
Can you start the car? If working properly, the siren will be accompanied by all the marker lights flashing and the car's ignition being disabled.
If you can still start your car, you may have to disable your siren. NOT A GOOD IDEA!
When the battery was installed, did the fuse on the positive side get damaged? Did any wires get pinched or otherwise shorted against the positive terminal or leads? Check all over that area to make sure all is well.
If you absolutely have to, you can pull the siren relay IF it doesn't disable your ignition too. AGAIN! I DON'T BELIEVE THIS IS A GOOD IDEA, but needs must as the devil drives.
If you disconnect it, get it into the shop as soon as you can. You don't want to be without your anti-theft system for long.
I wish you the best!
Apr 12, 2010 | 2001 Hyundai XG300
Shaver not turning on
Most likely, the rechargeable batteries need replaced. This model does not run directly from the cord. You can change them yourself if you can do some light soldering.
To replace them, you will need to remove screws on the back to take off the back cover. You can then remove the old batteries.
Batteries can be purchased at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
Feb 07, 2010 | Remington Microflex R-845 Electric Shaver
Computers & Internet Logo
David Payne
David Payne
