Question about Mr. Heater Portable Kerosene Heater - 175,000 BTU
Run fine for 10 minutes than white smoke - Mr. Heater Portable Kerosene Heater - 175,000 BTU
What would make the temp gauge on a 01 530i run all the way up to red and back to normal several times in a 10 minute trip?
Because its a BMW. The white smoke means your need a valve job on head. Probably losing some water thru head also.
Feb 17, 2014 | Computer, Chip, Cruise Control for BMW 5...
Puff of smoke from air vents.
You have a better idea than us, you saw and smelt the smoke.
Nov 01, 2017 | 2000 Ford Taurus
When starting from cold, white smoke not firing on all cylinders for about 10 seconds then run fine
White smoke usually means coolant is in the combustion chamber. It takes your Jeep about 10 seconds to burn it through. Probably have a bad head gasket or intake gasket. Have a Mechanic check it out.
May 31, 2012 | 1996 Jeep Grand Cherokee
Lt1050 black smoke after 15 minutes
The black smoke and black spark plugs indicate that the engine is running very rich (ie too much fuel). This could be caused by the choke not opening fully after the engine starts and the fuel mixture is too rich OR the fuel mixture setting is opened too far.
Check the choke lever, make sure the choke is fully open when the choke is in the running position.
When the engine is running with the throttle is in the 3/4 rev position then adjust the fuel mixture to get the highest RPM.
Apr 19, 2012 | Cub Cadet Garden
Engine starts and runs fine for five minutes or less then starts smoking and runs rough.
black smoke - oil in the cylinders
White smoke - water in the wrong area - probably a head gasket.
The head gasket is what I am hoping for because it is cheaper to do. And most instructions manuals from an autoparts store has step by step instructions.
If it is oil then you are looking at rebuilding or replacing your engine.
Take a look at both the oil and antifreeze to check for cross contamination which would verify the blown head gasket.
Jun 19, 2011 | Saturn SL Cars & Trucks
Started my 2002 ford taurus this morning just fine. Let it run for about 15 minutes before leaving fo work. When I came out my car was idling very rough and white smoke would come out the back then...
Have it checked at your local garage. White smoke from the exhaust system.....normally means a cracked cylinder head gasket. I would check the oil dipstick to ensure that there is no coolant in the oil pan. Coolant in the oil pan could mean a cracked cylinder head......a more costly repair.
Jan 18, 2011 | 2002 Ford Taurus
Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Mar 18, 2009 | Garden
Mr. Heater Portable Kerosene Heater - 175,000 BTU Logo
66 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
