Question about NetGear WNA1100 WirelessN 150 USB Adapter (WNA1100100ENS)
Please insert your adapter - NetGear WNA1100 WirelessN 150 USB Adapter (WNA1100100ENS)
The following message comes eventhough the adapter is inserted. "Wireless adapter not found. Please insert the adapter now".
You will need to install a driver for the adapter,You did not mention what type it is {brand] but you can go to the Device wbsite and download the proper driver
Aug 19, 2011 | D-Link DWA-125 Wireless 150 USB Adapter...
WHERE DO I PUT THE SD ADAPTER
Hello.
You don't need the SD adapter in your mobile phone. You may use it by inserting the micro SD card into the SD adapter, then insert the SD card adapter in a "SD card reader" and use it in a USB slot in your computer to access files from your "micro SD card".
I hope this helped you.
Thanks for using Fixya!
Please rate my answer.
Aug 04, 2011 | HTC Hero Smartphone
I have a problem with my phone, i cant download music, it says "memory card is in used by another application, please wait" Ive waited for about an hour, nothing happened, pleas help me
In that case please remove the memory card from the phone and insert it into the adapter and insert the adapter into the PC you want to copy songs from. Copy all the songs and reinsert the card into the phone. And you are done.
Feb 08, 2011 | Cell Phones
During installation, getting stuck on "detecting
Please restart your computer system. Try to reinstall the device only after installing the software first. Then please insert your adapter.
Jan 08, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
My adapter wireless N WN111v2 is not found
When I insert the adapter WIRELESS N WN111v2 during installation, a message said me : your adapter wirreless is not found !! Help me please
May 08, 2010 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
Powerbook G4/17. Had been running on battery, now dead
Hello, You can test your adapter using a voltmeter and see if the power comes in Best regards. The best is actually to test with another adapter
Jun 10, 2009 | Apple PowerBook G4 Mac Notebook
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
NetGear WNA1100 WirelessN 150 USB Adapter (WNA1100100ENS) Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
