Question about Coldtech J2GR-47L Commercial Refrigerator
Sliding rail is bent can i replace - Coldtech J2GR-47L Commercial Refrigerator
Sunroof will not close
check on the sun roof to see if the sliding rail on the truck has a dent or bent on the roof frame that it rides on.
Sep 06, 2014 | 2000 GMC Jimmy
How can I pry open an unlocked but Jammed file cabinet drawer?
The issue is probably a worn out drawer interlock - that is to prevent you from opening more than one drawer at a time so the unit will not tip over on you.
Remove one drawer and check the mechanism (worn out or bent).
JOAT
May 09, 2014 | Office Equipment & Supplies
How do I known if the front frame rails are bent
The checking of the frame rails for accident damage can be done easily. First place the vehicle over a flat clean cement floor. Select points on the frame rails such as front ends---suspension points---brackets attached to the rails on both sides and rear ends of rail. Make sure the points selected have a corresponding point on the other rail. Using a plumb bob drop the selected point to the floor and make a cross on the floor at that point. . Repeat the process for each selected point. The more points the easier to find where the rails are bent and by how much. Move the car out of the way and using a tape measure the distance diagonally between same points.-- EI-- from left hand front end to right hand rear end. Repeat the measuring from the opposite corners By measuring from one point on one side to the second point on the other side you will develop a continually crossing pattern of measurements. So in the end if you selected 4 points per side you will have 3 sets diagonal measurements on the floor or more . As you measure write the dimension on the floor. Now if there is a difference of more than 1/4 "(6mm)between any set of diagonals you will see if the rails are bent and if they are bent right or left or bowed in the middle. By measuring the heights of the corresponding points and recording them you will see if the rails are bent up or down. I understand it is a bit long winded but you will be in effect transposing the measurements of the points of the rails onto the floor so that the differences can be measured without the problems of items interfering with straight line distances.
Sep 20, 2013 | 1993 GMC Jimmy
Stuck slide drawer on ge spectra
Check to see if the glide rail has been bent of if something is actually pinned under the stove it self sometime tile or and rug will get caugh in the drawer. after that's all clear the only other issue I can see is if cleaners of some sort have drained down unto the drawer slide, or the drawer slide is bent or off track some how.
Jun 09, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
Bent and crack piston cross rail
sorry to tell you, you have to replace the connecting rod thats what there called drop the oil pan
Mar 17, 2013 | Cars & Trucks
My nail gun miss fires. seems there is not enough tension pushing the nails forward
Could be that the driver is not returning to top of the cylinder. Easy test, when the gun miss fires, remove air line, with thin metal, insert thru nose and push driver up. Retest gun. If driver was down a bit then nails will not feed. Remove head and check that driver oring is making good seal, lubed, and is not too tight or bent. Also check that lower bumper is not cracked or missing pieces. Replace parts as needed. If driver was all the way up, clean rails and pusher assembly with wd40 and follow with good cleaning with air. If pusher and rails working properly, must be problem with bad batch of nails, slightly thicker or wider head not allowing nail to easily slide. Open nose latch and check that nails slide thru easily.
May 10, 2011 | Porter Cable 16 - Gauge Finish Brad Nailer...
I have an older FR350 nailer. The coil return spring broke. I have the replacement and want to fix it. Do I have to take the whole nail guid assembly off to replace this part!
The best way to replace the spring is to remove the rails entirely. Take closeup photos of the gun from all sides with your digital camera or camera phone to help you with placement of all screws. You will need small clamp, small vicegrips and paperclip or piece of soft wire with small hook bent on one end to temp hold spring in place. With rails in hand check if pusher will slide out front of rails (some rails have a small casting preventing pusher from coming out front ~ remove tailpiece and slide out back ). Locate small screw /nut holding spring in place (keep this side of rails facing you). With new spring in place slide pusher into rails until you can catch the eye of the spring with bent wire at front of rails. While holding wire with vicegrip pull back pusher a few inches and clamp in place with c-clamp. Pull or let in bent wire to align eye of spring to attachment hole and install screw (you can leave bent wire in eye and just break off later. With screw attached break off wire and install rails to gun. Check sliding action of pusher before installing bolts at rear of rails. The pusher on some porter cable guns have plastic sliders that easily break with normal use and should be replaced as needed. Good luck.
Feb 08, 2011 | Porter Cable Air Tools & Compressors
The top rack is very stiff pulling in and out, at a certain point.
Check that the rollers on the rack are correctly seated in the sliding rail, and that all the rollers are ok and intact and turning.Also check that you haven't bent or dislodged the sliding rail and that it is fixed to the dishwasher properly, ie nothing has come loose.
hope that helps
Jan 25, 2011 | Hotpoint Dishwashers
Coldtech J2GR-47L Commercial Refrigerator Logo
19 people viewed this question
Top Coldtech Refrigerators Experts
Dan Webster
Dan Webster
Randy Justice
billconfused
Are you a Coldtech Refrigerator Expert? Answer questions, earn points and help others
