Question about LG WM-2277HW Front Load Washer
Rubber drain hose by drain flter clogged - LG WM-2277HW Front Load Washer
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
Remove the hose from the machine and remove the blockage using a stiff piece of wire.
Posted on May 04, 2016
2 Suggested Answers
  • 496 Answers
SOURCE: Clogged Drain Hose
There should be a spring clamp of some kind,use a pair of pliers to squeeze the clamp open and slide it off the hose.
Posted on Apr 23, 2012
My delonghi airadry slim is not draining through the hose
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Keep it in case you want to go back to the bucket.
Also, make sure the unit is higher than the drain and that the hose is not kinked or clogged.
Please rate 4 stars if this is helpful. Thanks and good luck!
Jul 29, 2017 | Dehumidifiers
2005 Chevy venture van evaporator coil drain clogged..what's the easiest way to get to it?
dreain is located under the hood in engine compartment on firewall area on passenger side of vehicle, look for a rubber looking hose down low on the firewall, normally you can remove hose and clean drain by blowing air in tube or sometimes crrap collects in the rubber tube, tube should pull right off, i have sneeped off end of the rubber tube so it has a bigger hole to drain and not plug up again
Sep 03, 2012 | Cars & Trucks
LG washer getting an OE error. I have opened the pump and drained the water as well as ckeaned the filter...still not working propperly.
OE means your machine has failed to drain within 10 minutes. There are a few posibilities. Your drain hose could be kinked or clogged causing the machine not to drain. Try using a shop vac to remove the water from the end of the drain hose. If a shop vac won't **** out the water either, you have a clog somewhere ing the drain hose, of the hose from the tub to the pump. If it will drain the water you need a new pump. If there is no water in the machine then the problem is either the pressure switch, the hose going to the pressure switch, of the control board. The pressure switch is on the back by the control board. You will see a black rubber hose going attached to it. Remove it and see if you can blow through it. If you cant it is clogged somewhere. If it is not clogged then the most likely cause is your pressure switch and next the control board.
Jan 30, 2011 | LG WM2101HW 4.0 cu.ft. Washer
When the air conditoner is on the passenger side floor boar fills up with water
you have a clogged drain for the heater/AC box
go under car safely, and find rubber hose and clear all debris
Jul 19, 2010 | 2004 Chevrolet Cavalier
Wont drain
The Hmming could say the pump works just fine. But I'm sure the not draining is caused a Valve in the Pump being dis-aligned or something. Try to contact service repair guys, or call and describe the fault :)
Apr 02, 2010 | AEG L62600 Front Load Washer
HI Dear water from dishwasher is leaking from
there is a cloged line between the air gap and the disposal (if you have one) or the drain under the sink.
you will need to remove the pipe and flush out with water. this is usually a rubber hose. most of the time, the clog is at the disposal where the rubber hose connects.
you should be able to see the clog once you remove the rubber hose. clean this out ( I use popsickle sticks) once cleaned out, reinstall the hose and try your dishwasher.
Oct 22, 2009 | Mountain Plumbing AG600S Air Gap for...
Evaporator drain hose clogged. Cannot find to clean out.
under the car at the base of the firewall on the passenger side..
Aug 13, 2009 | 2001 Mitsubishi Eclipse
LG WM2010CW filter drain no draining
In all likelihood the rubber drain hose is clogged. I had the same problem with my LG front loader. The hose was clogged with sand and dirt almost the entire length of the hose. The following solution is far simpler than taking the dryer apart to clear the drain hose. Besides I figure this same thing could keep reoccurring with all the sand and dirt we get in our clothes here in East Texas.
I purchased about 4 feet of 3/16 inch OD vinyl tubing and adapted it to fit on the end of a garden hose. The adapter gizmo included a valve so I could control the water flow and not give myself a bath. A picture of the gizmo is included below. Make sure that when you connect the water hose to the faucet that the faucet valve is just slightly opened and that the gizmo valve is closed. Using the gizmo is straight forward. First remove the drain filter and than insert the vinyl tubing in the end of the rubber drain hose and slowly open the valve on the gizmo. Make sure you have a large pan or bucket underneath the drain hose to catch the debris and water. Slowly advance the tubing up inside the hose until it won’t go any further. By this time water will also be running out of the drain filter cavity which will indicate the clog has been removed. Continue back flushing for a few more seconds to assure all the debris has been cleared, than clean up and you’re finished.
May 11, 2009 | LG Washing Machines
Clogged pump on Affinity Washer
Exactly the same problem. Washed a small area rug that appeared to have pretty much disintegrated. Machine would not drain. Got the same e 20 code. Checked the drain hose, and it was fine. Reamed the house drain just to be sure. Drum appears to have drained, but now the motor runs, and no water enters the machine. Both water hoses are flowing. No further error codes. Nada.
Apr 20, 2008 | Frigidaire ATF6000ES Front Load Washer
LG WM-2277HW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
