Question about Brother LS-2125 Mechanical Sewing Machine
Where can I purchase a shuttle race cover, a shuttle and bobbin case
Model number 1431
4 Suggested Answers
  • 25 Answers
SOURCE: cannot get the shuttle race and bobbin case in
Will the shuttle lock in place without a bobbin inside?  If it does, look for thread in there, wrong bobbin, etc.  If it doesn't, maybe the shuttle is bent?  Really hard to tell without seeing it...  Hope this helps.
Posted on Jul 15, 2009
SOURCE: bobbin and shuttle case pop out of machine .
You might need to clean the shuttle assembly.
1. Raise the needle bar to its highest position and remove the bobbin case.
2. Push levers sideways of the shuttle assembly and liftshuttle and shuttle race cove out by the center pin.
3. Clean the shuttle race of any lint or small particles of thread with a small brush.
4. Put a drop of oil on the center pin of the shuttle and on the shuttle race.
to reassemble, hold sjuttle by center pin and it carefull into assembly opposit the shuttle driver. Slip shuttle race cover into place. Snap the levers into position.
Occasionally remove the needle plate and clean feed dog with soft brush.
I hope that helps!
Posted on Sep 03, 2010
SOURCE: missing race cover
check with sewingpartsonline.com
Posted on Jan 25, 2012
Need bobbin case, shuttle race cover and shuttle body for a white sewing machine model 793... where can I find them?
Probably by finding a machine similar to yours and use its parts on your machine. Try auction sites like eBay...
Jan 23, 2017 | White Sewing Sewing Machines
How to remove sewing bed where fabric lays when sewing to get to bobbin area of Brother LS - 2020 sewing machine
http://download.brother.com/welcome/doch000256/l30ls17172020ug03enfrpoes.pdf
Lower bobbin threading Brother
  1. Turn the power switch to "o".
  2. Raise the needle to its highest position by turning the balance wheel towards you (anti-clockwise) and raise the presser foot lever.
  3. Open the shuttle cover behind the extension table on the the front of the machine and remove the bobbin case by pulling its latch towards you and pulling it out of the shuttle race. (fig A).
  4. Unwind about 10cm (4") of the thread from a full bobbin and insert it into the bobbin case. (see fig B-1). Pull the trailing thread into the slot then down and to the left, as shown in fig B-2, until it enters the delivery eye under the tension spring (fig B-3).
  5. Holding the bobbin case by the latch, fully insert the bobbin case into the shuttle race and release the latch. Make sure the bobbin case finger fits into the notch at the top of the race as shown in fig C.
Sep 13, 2016 | Brother Sewing Machines
How can I put back the suttle race cover and the suttle after I oiling them. In the manual dosen't clear.
Look at the race cover... it's got a couple of matching dents in one side where the little plastic "bunny ears" fit into them. The shuttle goes into the race, then the race cover goes over the shuttle, and you move the little plastic bunny ears into position to hold the cover -- the tips fit in the dents.
Then put in the bobbin in the bobbin case.
It's very much like this: http://www.manualslib.com/manual/85659/Kenmore-385-15208.html?page=68
May 14, 2014 | Husqvarna Husky 145
Brother XL-2022 Bobbin Problem
Removable parts are the race and bobbin case.
Raise the needle to it's at the highest position and set the race hook into the shuttle so the hook is at the lower left.
Re-place the hook race cover and move the levers or pegs to hold the cover in place.
Apr 18, 2010 | Sewing Machines
I need to know how to clean and oil the machine
From the Sears Kenmore manual:
Using a small brush, remove the lint that accumulates in the shuttle area and around the feed dogs.
To Clean the Shuttle Area:
  1. This area must be kept free of dust, lint and occasional tangled thread. Raise the needle bar to its highest point and remove the bobbin case.
  2. Push levers of shuttle race aside and lift shuttle race cover and shuttle out.
  3. Clean the shuttle race with a small brush.
  4. Put a drop of oil on the center pin of the shuttle and shuttle race.
Jan 25, 2010 | Sewing Machines
Where is the shuttle race on a Bernina Artista 180? I'd like to be exact as to where to put the drop of oil.
Just to the left of the bobbin case you will see a small lever. Remove the bobbin case and push the lever and that will release the latch which holds the race cover and shuttle (hook).
Clean well with a toothbrush and place one small drop of oil on the edge of the hook where it makes contact with the raceway. Place the hook back and snap the race cover back on.
Oct 01, 2009 | Bernina Artista 180
How to install bobbin
In the shuttle area there is a silver round piece- called the shuttle race cover. It has a black ear on the right and a black ear on the left. Push the right ear to the right, and the left ear to the left and the silver ring should come out. Behind the silver ring is the bobbin case stuck in the hook. Remove that, jiggle it, move it, just work the bobbin case out of the hook. Now put the hook back in the machine. In the machine there is a driver that looks like a half moon. Your hook looks like a half moon- make a full circle out of both of them. Re-install the race cover, pushing the left ear to the right and the right ear to the left to secure the race cover, and your problem should be solved.
Jul 07, 2009 | Necchi Sewing Machines
Bobbin don't turn
Jul 01, 2009 | Brother SE-270D Computerized Sewing...
Bobbin and shuttle case pop out of machine .
I hope that helps!
Apr 23, 2009 | Brother LS-2125 Mechanical Sewing Machine
Can't reassemble shuttle hook and shuttle race
the hook driver (still in machine) is 1/2 moon shape. The hook is also 1/2 moon shape. If you set the machine on its back, it's easier. Set the hook 1/2 into the other 1/2 of the hook driver to make a circle. Then put the hook cover on (machine still on its back) with the tabs for the twist locks pointed out. Needle gaurd to the top of the machine. Snap the twist locks in place and viola!
Kent
Mar 16, 2009 | Baby Lock BL1556
Brother LS-2125 Mechanical Sewing Machine Logo
12 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
