Question about Microsoft Xbox 360 Console
Wont turn on 3redlight
And there is no solution im sure of whan i turn it on three red lights come on on the on/off buttonand the missing light
  • ganster Oct 27, 2007
    found solutionsssssssssssssssssssss!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!just call 1800-4my- xbox
  • 30 Answers
Either look on www.microsoft.com and enter "X Box 360 - rings of light" and it will give you the answer to your problems, or call 1800-4my-xbox and they are a great help.
Mick
Posted on Nov 14, 2007
SOURCE:
Im in dual mode but my remote for tv 1 is not doing anything what do i do
Hi there, Cheri Torres with DISH Network Customer Service. Icame across your post and wanted to see if I could help. It sounds like yourremote may need to be readdressed to your DISH receiver box. You are going towant to check your batteries first to make sure that they are fresh if not try replacingthem. Once you have changed your batteries, try pressing the SAT mode buttonand hold it down until all other mode lights light up red. If both options donot work try readdressing the remote to the receiver, I will list here for youthe instructions for addressing your remote. I hope you find this informationuseful and if you have any further questions please feel free to post back hereor email me at Cheri.Torres@Dishnetwork.com. :)
Mar 03, 2011 | DISH Network IR Remote Control
One red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
May 15, 2010 | Invacare Supply Group Invacare Pronto M91...
Is the two red light problem the same repair as the three light problem?
No . The Three red light repair sometimes causes the 2 red light problem.
The Problem is either your G.P.U or C.P.U has broken it's thermail
seal from the heat sink , and will need to be re-seated to restore normal
operation .
You can do this yourself by firmly and evenly pushing down on
both heat sink . then check and repeat if needed.
Or you can have a repair shop re-seat the heat sinks , im
no sure how much they would charge ,maybe 40.00-50.00?
If you have any question's just comment and ill respond.
Rob
Oct 13, 2009 | Microsoft Xbox 360 Console
Beep 3 times turns green yellow then blinks red then turns to a solid red wont turn on wont give me game
3 Solid Red lights usually means that a cable is unplugged. Check all cables (unplug and plug back in)...you may need to replace power cable if issue is still ocurring. If it is 3 Flashing red lights, this is known as the Red Rings of Death, i.e. your XBOX is dead and needs to be completely replaced.
http://www.xbox360forum.com/forum/xbox-360-console/64180-what-do-three-solid-red-lights-mean.html
Jun 16, 2008 | Video Game Consoles & Games
Smae thin
Did it turn on Prior to you taking it apart?  If so then it is most likely the ribbon cable between the switch and the mainboard.
Oct 27, 2007 | Sony PlayStation 2 (PS2) Console
3red lights, wont turn on
well,this happened to me one time, so I unplugged the cosnole and waited 15 minutes.. make sure the remote has fresh batteries too.  If that doesnt work, call microsoft, i heard they increased the warranty on xbox 360. 1-(800) 4MY-XBOX (469-9269
Oct 26, 2007 | Microsoft Xbox 360 Console
Three red lights
You have encountered the infamous 'Red Ring of Death' problem that occurs in many Xbox systems. The lights are actually separated into four seperate areas, and depending on which ones are red for you is supposedly some error code (either hardware, software etc). In most peoples cases they need to get it replaced. (this is a widespread problem for Microsoft, and they usually do all the work for free). Your first options would be to run through all the normal things, unplug it, remove and reseat the harddrive, etc (I'm sure you've tried all this many times over by now). The second thing to do is call Xbox support at 1-800-4MY-XBOX (9am-1am est, 6am-10pm pst). The first things they will probably have you do are the things I mentioned above. When they don't work, they will most likely be sending you a box in which to send them your machine for repairs. My suggestion is to do it as quickly as possible. The least amount of Halo3 you miss, the better
Sep 21, 2007 | Microsoft Xbox 360 Console
3 flashing red light on console
uh well u got the three red lights of death it sounds like... and i also had those. while im no expert on this stuff, iv seen that u can put ur 360 sideways on a table, wrap it in towels(and i mean like 2 towels, wrap it up completely) and turn it on and leave it on for about 10-15 mins. just make sure a fire doesnt start in those 10-15 mins(believe me you dont want to call the fire company and tell them u started a fire wrapping ur game console in towels), ok then after u done waitin turn it off, unwrap it, and let it sit until it is cool, and try turning it on. it might work, its supposed to work because those three red lights mean that theres a malfunction in the 360 itself, such as wires or sumthin, and extreme heat may melt the wires and fix the problem, how i dont know but theres so many stories of ppl who have pulled it off
Sep 13, 2007 | Microsoft Xbox 360 Console
Sony SNC-P1
I think it is Guest for both OR try Sony SNC-P1 for both logon & password ... good luck.
Aug 08, 2007 | Sony SNC-P1 Network Camera
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
