Question about Shredder Secure Shred Shredder
Need power cord for shredder
Lost power shredding cord
2 Suggested Answers
t_vinson57
  • 58 Answers
SOURCE: need AC power cord
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
My shredder won't shred
If the motor will not run, then probably there's paper clogged in the shredder. Turn over the shredder, after unplugging the power cord, and remove the papers.
If the motor will run but not shredding any paper, then the drive gear has broken teeth. This is not usually worth fixing.
Hope this helps.
Mar 27, 2015 | Shredder Office Equipment & Supplies
No power. worked perfectly last shred. Now no lights illuminate when switch is on,
Does the outlet it's pluged into have power? check with another appliance. If power could be a number of things, plug connection to cord, connection inside, switch. Did the shred actually finish or did it stall and still som inside?
Mar 17, 2015 | Office Equipment & Supplies
My Black & Decker Shredder #BD-61 all of a sudden does not work. I used it tonight, but the next time I tried it does not work. The lights come on in both positions, but
On some shredders when both the forward and reverse LEDs are on it can indicate either a jam or a full receiver bag/ container (the area that the shredded paper is fed into).
Try the following steps:
  1. ) unplug the power
  2. ) open up the shredder (see 1 on diagram)
  3. ) empty out all the shredded paper (see 2 on diagram)
  4. ) check that the shredding jaws (both the entrance and exit) are clear of any shredded material (see 3 on diagram)
  5. ) put everything back together
  6. ) plug power cord back in
  7. ) force the shredder into reverse (see 4 on diagram)
Hopefully you should hear your shredder motor running. If it is switch it to automatic and try shredding again
Jan 24, 2015 | Shredder Office Equipment & Supplies
I have a small secure shredder you can hold it your hand.
Even a small machine needs a powerful motor to shred 12 sheets at a time which this one is rated for. So I would guess a 13 amp rated lead is safest.
Mar 11, 2014 | Royal 112MX Shredder
Mailmate by staples shredder won't shred
drive is seized-remove power cord- open cover rotate cutting drum slowly using motor drive gears - look for debris/gear teeth missing
Mar 02, 2014 | Office Equipment & Supplies
I've lost the manual what is the maintenance on the VF 1700mx
Shredders need no "real" maintenance......if you can open the top cover once per year and clean out any debris that might build up inside...other than that just occassionaly put some shredder oil onto a sheet of the paper you are shredding to help in lubrication/cleaning of the cutting teeth of any builld-up of dust and debris that take place during the shredding process.
Jul 18, 2011 | Royal VF1700MX Shredder
THE SHREDDER ISNT SHREDDING ANYTHING ANYMORE, the power still runs and it will still take the paper but its not shredding anymore???
You wil need to Have the shredding head rebuilt or replaced. and or a new machine. A new head is very expensive. Here is the number for fellows 800-955-0959. Check on parts if they are still available. Hope this helps your friendly service tech (colorado).
May 06, 2010 | Fellowes Powershred 220 Shredder
I have a SECURE-SHRED (tm)shredder, approx. 10 years old, which will not operate at all. Is there a likelihood that it might be the power supply? If so, where can I obtain a replacement power supply? TDC...
Probably more practical to replace with a new shredder. There are several standards though.
If you wiki or google shredder standards you can check this stuff out. So if you're doing crazy stuff and you need it shredded like Enron did then go with one of the new Federal Standard type shredders, otherwise risk electrocution or a small fix if you try to fix it your self - time / money in doing so as well.
Thanks!
Jan 20, 2010 | Shredder Secure Shred Shredder
Need AC power cord
Good luck, Tom
Jan 04, 2009 | Shredder Secure Shred Shredder
My shredder stop shredding. has paper caught in it
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Aug 29, 2007 | Quartet gbc 6120S Shredder
Shredder Secure Shred Shredder Logo
57 people viewed this question
Top Shredder Office Equipment & Supplies Experts
Ross Keen
Dave Reilly
Level 1 Expert
Gilbert Ruiz
Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
