Question about Davis Instruments Davis Vantage Vue Weather Station
Console will not display after battery change on Davis vantage vue
I changed the batteries in the console and the display only says "receiving from 1"
Display lights up but no information displayed
did you change the batteries or are you using a power cord?
Mar 25, 2014 | Nordic Track Nordictrack Ack Asr 630...
Outside temp
Remove all batteries. Reinstall batteries (or new ones) in the outside unit. Install batteries in the console. DO NOT TOUCH ANYTHING! Wait until the outside temperature displays on the console. Make any adjustments necessary.
Nov 05, 2013 | Davis Instruments Davis Vantage Vue...
Magellan roadmate 2036 how to set my local time
1. From the
Main Menu screen, tap the Settings icon .
2. Tap
System.
Setting Languages
1. Access the
System Settings menu (above).
2. Tap
Languages.
3. Tap on the desired language.
4. Tap the back arrow .
5. The Magellan RoadMate receiver will reboot if you change the language.
Setting Auto Power
Auto power is the duration of time that the Magellan RoadMate receiver remains idle before turning off
automatically.
1. Access the
2. Tap
Auto Power.
3. Tap on the desired duration.
Setting Brightness
1. Access the
2. Tap
Brightness.
3. Tap in the brightness slider to set the brightness of the display.
The
Dim on Battery Power option will prolong battery life by dimming the display while using internal battery
power. Check to turn this option on.
Setting the Time Format
1. Access the
2. Tap
Time Format.
3. Tap on 24 Hours or 12 hours with am/pm.
Selecting the Time Zone (daylight savings on/off)
1. Access the
2. Tap
Time Zone.
3. Check Auto Time Zone or select your time zone from one of the cities in the list.
Jun 27, 2011 | Magellan 2036 GPS Receiver
I changed the batterys in the reciever remote as the system sid batterys where low now I cannot get the remote to respond
Ensure that the batteries are inserted the right way, if they are not the remote will not get power.
Make sure to hit the STB button and then press the POWER button.
Hope this helps!
Mar 07, 2011 | Bell Televison & Video
How do you turn it on.
HI, try these steps...
  • 1
  • Change the batteries. Sometimes this seems like a simple and obvious step, but is often overlooked. The Leapster console runs off of four AA batteries.
  • 2
    Hold the power button on the Leapster console. If you still do not see a display on the screen with a fresh set of batteries, then you got one of the bad consoles. This was a bad batch of consoles that were sent out by Leapster.
  • 3
    Contact Leapster customer support. They should be able to replace your Leapster learning system free of charge. With all of your information ready, it should be quick and easy to get a replacement console.
  • Feb 20, 2011 | Leapster 2
    Operating instructions for EM-2R power meter. it has 3 plug-in sender units with remote reader. How do I resynch the senders and reader after replacing battery in reader? Cheers DaveK
    I have what appears to be the same device. My instructions list the following method:
    1. turn off or disconnect all the remote monitors.
    Use the code button on the display module to set the channel. It displays 1 --:-- for channel 1.
    Plug in the first remote sensor into the power outlet and press and hold down the SET button until the LED flashes.
    The receiver will show numbers where the dashes were in the display.
    Change the channel on the receiver to 2 withb the code button, it displays 2 --:--.
    Plug in the second remote sensor, press the set button till the LED flashes.
    Repeat for channel 3 with the third remote sensor.
    This is the same method used to set them up the first time. Having to turn off or unplug the device is the unintuative bit. I assumed it would reconnect after replacing the batteries.
    Dec 19, 2010 | Kitchen Appliances - Others
    PS3 controller has 4 red flashing. Console has green, display OK. No response from PS button with USB connect or not. 5volt on 1 USB is on and off, other OK Help please
    4 flashing means it has a dead battery leave it plugged in with the system on. if that doesnt work change the cable reconnect and leave it to charge good luck
    Sep 09, 2010 | Sony Playstation 3 (PS3) Console
    System date error! please check NDS System date on R41 card
    I had the same problem. I fixed it correcting system date *before* the real date ( 1 day before in my case). It worked!!
    Oct 26, 2009 | Nintendo DS Lite Console
    Center Console Display Not Working
    Changed the battery yesturday in my Mazda rx-8. Now my radio/CD and my A/C won't work! It's all black! Wot to do???
    Jan 28, 2009 | 2004 Mazda RX-8
    Davis Instruments Davis Vantage Vue Weather Station Logo
    Top Davis Instruments Measuring Tools & Sensors Experts
    Vuk B
    Tom Chichester
    Are you a Davis Instruments Measuring Tool and Sensor Expert? Answer questions, earn points and help others
