Question about Sony XPLOD CDX-GT200 CD Player
No buttons functioning only power and cd just keeps displaying all menu items and stays on clock
Set clock and keep it displayed
Disable DEMO in MENU to disable colors from flashing on screen
Nov 01, 2014 | JVC Kd-s48 In Dash Cd / Ipod Receiver
Locked out
The setup Security Code can be done when the
<Demonstration mode Setting> (page 50) is set as OFF.
• When the Security Code function is activated, the code
can’t be changed and the function can’t be released.
Note, the Security Code can be set as the 4 digit number
of your choice.
1 Enter Standby
Press the [SRC] button.
Select the "STANDBY" display.
2 Enter Menu mode
Press the [MENU] button for at least 1 second.
When "Menu" is displayed, "Security" is displayed.
3 Enter Security Code mode
Press the Control knob for at least 1 second.
When "Enter" is displayed, "Security" is displayed.
4 Select the digits to enter
Push the Control knob to [4] or [¢].
5 Select the Security Code numbers
Push the Control knob to [FM] or [AM].
6 Repeat steps 4 and 5, and complete the
Security Code.
7 Confirm the Security Code
Press the Control knob for at least 3 seconds.
When "Re-Enter" is displayed, "Security" is
displayed.
8 Do the step 4 through 7 operation, and
reenter the Security Code.
"Approved" is displayed.
The Security Code function activates.
• When the wrong Code is entered in steps 4 through 6,
repeat from step 4.
Press the Reset button and when it’s removed
from the battery power source
1 Turn the power ON.
2 Do the step 4 through 7 operation, and enter
the Security Code.
The unit can be used.
In Standby mode
Touch Sensor Tone
Setting the operation check sound (beep sound)
ON/OFF.
Display Setting
"Beep : ON" Beep is heard.
"Beep : OFF" Beep canceled.
In Standby mode
Manual Clock Adjustment
• This adjustment can be done when the <Synchronize
Clock> (page 43) is set as OFF.
1 Select Clock Adjustment mode
Select the "Clock Adjust" display.
2 Enter Clock Adjust mode
The clock display blinks.
3 Adjust the hours
Adjust the minutes
4 Exit Clock adjustment mode
Press the [MENU] button.
The Whole manual is here.
http://www.kenwood.net-disp.com/i/05products/kdc_x789/pdf/kdc_x889_x789_mp828_k_english.pdf
Dec 06, 2007 | Kenwood KDC-MP628 CD Player
New hyundai i30 has clock set to wrong time. the manual gives instructions to re set the clock for a different radio/cd player model to the one i have. mine does not have a SET UP button. in its place it...
Press the radio on button and hold down.
A menu appears, displaying Adjust Initial Volume, release the power button.
Turn volume button to the right to display the Clock menu item.
Press the power button to select the Clock Menu item.
Rotate the volume button to adjust the hour.
Press the power button to move to minutes adjustment.
Rotate the volume button to adjust the minutes.
Mar 17, 2011 | Hyundai Accent Cars & Trucks
Set clock
Set the unit to STANDBY mode. Press and keep pressed the MENU button for about a second. Now with the control button on the right, select CLOCK ADJUST. Now press and keep pressed the control button for about a second. The clock display should be blinking now. Moving the control button up/down and left/right will set the hours/minutes.When done press the menu button once. You should now have a functioning clock. Here is a link to Kenwood support page:http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/ select your model from the model drop down list, it's there. or send me your email and i will send you the PDF file myself. It is always a good idea to keep the manuals of all your equipment. dreamsystems
Feb 11, 2011 | Kenwood Excelon KDC-X789 CD Player
Cant adjust the time o the clock
  1. Select Clock Adjustment item during Menu mode (In Standby mode see below for standby mode explained). Select the "Clock Adjust" display.
  2. Enter Clock adjustment mode. Press and hold the control knob for at least one second. The clock will blink.
  3. Adjusting the clock. Push the control knob towards the left or right to select hours or minutes. To adjust each item turn the control knob or push it towards up or down.
  4. Exit clock adjustment mode. Press the (FNC) button.
  • Turn on the power.
  • When the power is ON, select a source.
  • SRC Select mode 1: PRess the (SRC) button and then turn the Control nob or push it toward left or right.
  • To determine the selected source, press the Control knob.
  • SRC Select mode 2: Pressing this button each time switches between sources.
  • Turner ("Turner"), USB or iPOD ("USB" or "iPod"), CD ("Compact Disc"), Auxiliary input ("AUX"), and Standby ("STANDBY")
  • Press at least 1 second to turn off the power
Nov 10, 2010 | Kenwood KDC-MP538U Car CD/ MP3 Player
How do I set the clock on my Kenwood kdc-2025 cd player?
Press [MENU] for at least 1 second. *MENU* is displayed. Press [FM] or [AM] button to select menu item (CLK ADJ). Press RWND or FFWD button for at least 2 seconds. The clock display blinks. Adjust the hours. Press [FM] or [AM] button. Adjust the minutes. Press the RWND or FFWD button. Press [MENU] button to exit adjustment mode. Reference page 20 in this link to your Kenwood KDC-2035 Operating Instructions.
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDC-MP225.pdf
Dec 27, 2009 | Kenwood KDC-2025 CD Player
Clock setting on Pioneer DEH-P77DH in dash cd player
Setting the Time
This is the mode for setting the time on the unit’s clock display. (Refer to page 51 for
details concerning the clock display.)
As soon as you switch to “Minute”, the seconds start counting from 00.
1. Press the FUNCTION button and select the Time setting mode in the InitialSetting Menu
always select “OFF”.
2. Select “Hour” or “Minute”
with the < / > buttons.
3. Set as desired with the ^ / v
buttons.
Jan 04, 2009 | Pioneer DEH-P77DH CD Player
Help
press and hold the mode button for several seconds until the display stops flashing
you will then see a particular part flashing adjust by using the up or down buttons then press the mode or set button to move on to the next item
Oct 16, 2017 | Sharp CD-SW200 CD Shelf System
Clock
To set the clock on a Pioneer head unit:
Hold the 'Source' button until the unit powers off.
Hold the 'Function' button until an item appears on the screen and starts flashing.
This is the 'Initial Settings' menu, where you can set the clock and more depending on the head unit model.
Press and release the 'Function' button to switch between options in this menu and use the left/right/up/down arrows to adjust settings for any option.
Feb 24, 2008 | Pioneer DEH-P4000 CD Changer
Sony demo
Had the same problem. The display of the home cinema system kept showing "sony demo". I went to the system menu and reset all settings to factory!
Nov 20, 2007 | Sony CMT-M100MD\W CD Shelf System
Sony XPLOD CDX-GT200 CD Player Logo
20 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
