Question about Kenmore 74602 Gas Dryer
Timer ticks but dryer wont start - Kenmore 74602 Gas Dryer
5 Suggested Answers
shinn8
  • 85 Answers
SOURCE: Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Posted on May 27, 2009
  • 2516 Answers
SOURCE: Dryer wont run, lights work, timer clicks
what is the model number?there are a couple of things you can check with the little info you sent,check the door switch,push the paddle in and out ,if it doesn't click it's bad,check to see if the belt broke,on some dryers there is a switch down near the pulley,if the belt brakes the dryer won't run,one more thing if your dryer hasn't had a clean out in a long time or if your clothes have been taking a long time to dry check the thermal fuse located on top of the blower wheel housing,if the lint filter is on top the fuse is in the back,take off the vent line,remove the back panel and check the fuse located to the right and down near the bottom of the duct that the lint filter slides into,if the filter is inside then the fuse is in the front the fuse is on top and to the right of the blower wheel housing,also you should clean out the duct that the filter slides into,blow out the vent line,check outside and make sure the flapper is not blocked with anything and vac out the inside of the dryer where the motor is,you need to do this once a year anyway,if you still need help send the model number and let me know what you find,unplug the dryer to clean it and when working on it and remove one of the wires when using your meter
Posted on Mar 17, 2010
heatman101
  • 43501 Answers
SOURCE: Electric dryer wont start.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 27, 2011
machinetech7
  • 1344 Answers
SOURCE: kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Posted on May 01, 2012
Dryer doesn't start
Actually, it's probably the switch under the button meeting its demise.
Jan 14, 2018 | Whirlpool Dryers
Dryer makes a ticking sound when the door is closed but wont start. If I put the dial on off, then the ticking goes away....help
the ticking noise is the timer, you dryer is not starting:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Feb 25, 2011 | Maytag PYE2300AY Electric Dryer
My dryer wont start when I push the start button. You can hear the tick, tick when turn the timer on. Is it the start button or thermal fuse?
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Nov 22, 2010 | Dryers
Kenmore dryer makes the ticking noise but when we push the button to start the dryer it wont start. What should we look at?
Please check your Thermo fuse
and ticking noise should not be there unless the dryer is on which means that your timer is acting up
Oct 30, 2010 | Dryers
Maytag dryer Model MDE3000AYA intermittently won't start. Interior light does illuminate when door is open. Normally when the timer knob is set a soft audible ticking sound is heard. When the dryer...
could have a bad timer,when it stalls try tapping on the timer or wiggling the knob to see if it will start,there's a little motor on the timer that you hear ticking and it could fail.
Jul 10, 2017 | Maytag Dryers
My dryer will not start when I push down on the dial. There is power to the dryer. When I turn the dial on to the timer, I can here the ticking sound, so the timer is working, but it wont start when I...
Maytag Performa Mod.PYET244AYW wont start has power door switch good thermo protection good at element cant fin any fuses timer has 120v and selecter switch
Oct 14, 2010 | Maytag Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Kenmore 74602 Gas Dryer Logo
35 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
