Question about Microwave Ovens
How to change the internal light bulb on a belling bel stw25a
Internal light dim
3 Suggested Answers
SOURCE: Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Posted on Nov 26, 2009
beltronic205
  • 1467 Answers
SOURCE: SIZE OF INTERNAL FUSE
Check to see if its marked on the panel itself could be an 8 amp 1.1/4 inch size ...you must fit the correct amp fuse for safety also be careful as the Capacitor may hold a charge and can be lethal voltages within...good luck.
Posted on Apr 12, 2010
My belling BEL F-SE60DOMW microwave will not turn off
You might have a power relay with contacts stuck in the closed position. I'd also check the door switches to make sure both the primary and secondary are not stuck closed. It's an unlikely cause, but I'd check them anyway.
Dec 23, 2016 | Belling Microwave Ovens
How to replace bulb on BEL STW25
Sometimes this can be done form the inside other than that you will have to take the lid of it
Jan 08, 2015 | Belling STW25 900 Watts Microwave Oven
When the microwave is cooking the light inside dims. When done cooking the light returns to full brightness. Is that normal or is there a problem with the microwave?
I've seen this with most microwave ovens I've had. When the microwave emitter kicks in to cook, the unit uses much more power, providing less to the internal bulb, which dims a bit. Unless it's very dramatic, for example the bulb turning off or going almost out, it's normal behavior. If the bulb is going very dim or out, it could be that the circuit it's connected to isn't providing enough amperage to adequately run the oven. In the case of your microwave, it's rated at 15 amps, so should have adequate power on a standard household circuit by itself.
Apr 09, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
SIZE OF INTERNAL FUSE A Belling BEL-CJ/SS25 Combination microwave oven The fuse has blown and the size printed on end cap unreadable any one any idea as to its value as it reads like T8H250V
Apr 12, 2010 | Microwave Ovens
Bulb replacement model BEL/CJS21
You need to take the 5 screws out on the back and side oc the cover - 2 are a special screw head but if you jam a small flathead screwdriver in you can snap off the tiny stud so that you can now use a star driver. (be prepared to damage the screwdriver head). The bulb can be seen in the black plastic assembly surrounded by wires. You can just about unscrew the bulb with 2 little fingers - hey presto squeeze new build in and pug covet back on
Jan 24, 2010 | Belling Microwave Ovens
Sep 04, 2009 | Microwave Ovens
Instruction manual for Belling Combi oven BEL-CJSS25
Did you try this?
Lines are open Monday to Friday 8am - 6pm and Sunday 10am - 2pm.
Belling Customer Care: 0871 22 22 503
Or maybe this?
Belling Product Helpline
0871 22 22 635
Product Helpline Open Times
Monday to Thursday
9am - 5pm
Friday
9am - 4.30pm
Spare Parts
0871 22 22 506
Nov 24, 2008 | Belling Microwave Ovens
Microwave Ovens Logo
15 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
