Question about Quartet gbc 32S Shredder
How to open shredder when screews are removed
Looking at the label on the bottom, peel off the left side of the label about one inch and you will find a hidden Philips screw just like the other 6 on the bottom and the parts separate easily.
Posted on Feb 23, 2016
How to open fellows s701 cm shredder?
There are six Phillips head screws around the perimeter of the underside, plus one more hidden screw in the center under a label. Then the cover just lifts off ...
May 18, 2014 | Fellowes S701CM Shredder
The shredder is saying the door is open but there is no door on the shredder
It may not be a 'door' but there is a protective cover over the shredder blades and that can be removed. A sensor sees if it is properly in place. Try removing the top and replacing (power off of course)
Apr 24, 2014 | Staples Office Equipment & Supplies
Shredder will not operate in forward mode.
Sounds like the bin might be over full. Switch machine off. Remove top section, or open door, Empty bin. Look at shredder blades to make sure nothing is stuck in them. When sure blades are clear put back together and then switch on.
Mar 18, 2014 | Royal 15MX Shredder
Led sensors on the bottom
superflykitt:
Disconnect the power cable and remove the cutter head from the top of the paper bin. Turn the shredder head upside-down and remove the screws holding the shredder head cowling together. Open the cowling and you will see the slot where the sensor fits (on one side of the paper feed slot bottom side.
Aug 29, 2012 | Fellowes FS5 Shredder
Open the head cover
There is a seventh screw under the label.
Apr 07, 2012 | Fellowes P50CM Shredder
The shredder developed a jam. I removed the bin and the top of the shredder. I removed the shredding mech. and removed the paper material. Reassembled the shredder. Shredder starts up when paper is...
Does the motor run??? even in reverse???
If the motor doeas not run at all it probably PCB. If the motor does run but the cutting mechanism does not turn then you probably have stripped/broken plastic gears... open and check,...contact Royal at 1-800-524-0799 for parts assistance.
Oct 27, 2010 | Royal VF880 Shredder
How do i remove the rear rotor? 2001 chevy blazer 2 wd
tools needed are hammer and screew driver, remove the screews and the tap with the hammer in the center then light tap from side to side
Jul 28, 2009 | 2001 Chevrolet Blazer
Open top
Remove the bag holder...look up inside and see 4 screws to remove.
Jun 28, 2009 | Memorex MPS1500 Strip Cut Shredder, With...
Replacing control board
There are two screews onder the shield. You need to get level with the shield to see them. Remove the two screews and it should come off no problem. Now to get in to the controll panel you have to pull the oven out and there are two screews on the back in both top corners to get in side to the control board. Good luck
Dec 16, 2008 | Maytag MER5775Q Electric Kitchen Range
I am trying to replace the control board on a maytag mer5755qaq and need to remove the heat/visor shield. How do I do this? Please help!
Dec 16, 2008 | Kitchen Ranges
Quartet gbc 32S Shredder Logo
173 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Pie-man
Level 1 Expert
graybeard32301
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
