Question about Maytag MHW6000XW - MaximaTM High-Efficiency Front Load Washer
HOW DO YOU ACCESS THE PUMP FILTER ON AN OLDER MAYTAG MAXIMA FRAONT LOAD WASHER
SOURCE: maytag washer
Take motor and pump assembly off and turn upside down. Soak shaft with lube oil,wd40 ect.
should pull straight up. They are known to stick and brake,(the pump)so be gentle.
Posted on Feb 05, 2009
co7196
  • 3433 Answers
SOURCE: Maytag Legacy Series Washer. Lint settles on
Lint is in majority flushed out in drain cycle. make aire the tissue and match books aren't in any pockets. the lint is then deied and separated in the drier , Well so I was told . good luck
Posted on Jun 15, 2009
  • 3600 Answers
SOURCE: removing the shell to replace pump hoses on older maytag washer
go to this web site and look at picture so you can see how it is taken apart. Please rate if this helped, if you need more asstance, post here and if this was helpful please rate, and thanks for using fix-ya
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5177917
Avid101
Posted on Aug 28, 2009
dcramer531
  • 1654 Answers
SOURCE: 11 year old maytag neptune
  • Do not open from behind! First drain as much water from the drum as possible. and unplug from the outlet. Then there are 2 screws left and right under the front lower panel at floor level. Undo those two screws. Pry the front panel DOWN from the door panel. Once the lower panel is removed you will see the pump and pump filter on your right. The pump filter is to the left. It has a large turnscrew. Be ready with a pan or something to catch the water from the open filter! You can also use a shop vac and drain it from the drain hose by sucking the water out. Screw this counterclockwise until it comes loose. You will now be able to remove the filter and all the debris. After cleaning, re-screw the turnscrew. Before you put back the front panel test that it is clear by doing a wash. If it still doesnt drain you must remove debris from the pump itself. The pump is between the pump filter and the pump motor on the right. Undo the white clips from the motor and the retaing clips attiching the filter to the metal washer body. Then turn the motor clockwise to separate it from the filter.
    BTW - on the back of the front panel are the SERVICE INSTRUCTIONS with a warning - Technicians only. The manufacturer keeps the instructions for doing this and many other simple fixes 'secret' so that their techs can use these.
  • Posted on Feb 19, 2011
    • 6277 Answers
    SOURCE: maytag bravos washer - how
    Following are my complete and hopefully 'coverall' guidance notes for checking both the drain motor filter and the drain motor ;-0)
    REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
    If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
    It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
    Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
    At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
    If this has assisted you please consider a 4 thumbs up for the rating.
    Thanks and good luck!
    John C
    Posted on Aug 22, 2011
    Maytag maxima XL washer is not spinning out the water how can I fix this?
    Pump, filter or drainage problem.
    Check there is nothing jammed in the pump or the filter.
    Make sure the drain is not blocked or running "up hill"
    Mar 14, 2016 | Maytag MHW6000AW Maxima XL 27" White Front...
    What are the error code for F09 and E02. for maxima maytag
    If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
    Dec 09, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
    Error code f09 e01
    Did you clean the tube that goes from the tub to the drain filter then the drain pump it is behind the front panel also make sure there is nothing in the drain pump stopping the impeller from turning.
    Jan 29, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
    Getting E02 and F09 error codes on my Maytag Maxima MHW6000XW front load washer
    Here is the manual. Hope it helps: http://www.applianceblog.com/mainforums/attachment.php?s=001fc13abc99c02a4aa812a23c01ac7e&attachmentid=13030&d=1381289434
    Jan 05, 2014 | Maytag MHW6000XW - MaximaTM...
    My machine wont spin out
    Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
    Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
    Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
    Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
    Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
    Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
    Close the door completely. The washer will not operate if the door is not securely closed.
    I hope the above helps.
    Good luck.
    Jan 12, 2011 | Maytag Neptune MAH5500B Front Load Washer
    Mav408daww washer knocking sound, won't spin all the water out..
    Take care.
    Jan 12, 2011 | Maytag Legacy Series Top Load Washer
    What is wrong if it is not spinning to extract water?
    Good luck.
    Jan 11, 2011 | Maytag MHWZ400T Front Load Washer
    Washer wont spin out displays 5d code
    Good luck.
    Jan 11, 2011 | Maytag Bravos MTW6600T Top Load Washer
    It starts to spin slow then quits.
    Good luck.
    Jan 10, 2011 | Maytag Neptune FAV6800AW Top Load Washer
    Maytag Washer
    follow the below procedures on how to Troubleshoot a Front Load Washer That Won't Spin or Drain;
    1. Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
    2. Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
    3. Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
    4. Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
    5. Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
    6. Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
    7. Close the door completely. The washer will not operate if the door is not securely closed.
    Good luck.
    Jan 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
    Maytag MHW6000XW - MaximaTM High-Efficiency Front Load Washer Logo
    282 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
