Question about Denon AVR-2500 Receiver
BOOM SOUND AT AUDIO MODE CHANGE
WNEN I CHANGE AUDIO MODES ON THE RECEIVER I GET A BOOM FROM MY SUB WOFFER THAT WAKES UP THE HOUSE. ALSO, A FEW SECONDS AFTER TURNING OFF THE SUB W I GET A LOUD FART SOUND FROM THE SUB W.
DO I HAVE A SUB W PROBLEM OR A RECEIVER PROBLEM OR BOTH?
Suggest turning the volume down on the Receiver/Amp before changing modes. Changing modes can produce signals that can hurt speakers if driving at mid-high levels.
Regarding the sub, turn off the receiver first, then turn off the sub. When turning everything on, turn on the sub first, then the receiver. If you still hear the noice in the sub, turn down the volume in the sub before turning it off (making note of what volume level you prefer for it when it is on).
Posted on Nov 05, 2007
  • Gary Morgan Nov 23, 2011
    Did you ever find a solution to this problem? I recently started having the same problem after 15 years of perfect operation! Please respond to gkmorgan@att.net
I've had a Pioneer receiver hooked up to have surround sound and I have used this to play music throughout my house in bedrooms, to play Blu Ray and TV which have all worked fine. I had a guest in my home...
go through the input modes its one of them leave it each mode on for 30 seconds what output do you have for audio on the blueray. It can also be setting for audio from blueray was turned off swich to fiberoptec
Mar 04, 2015 | Pioneer Audio Players & Recorders
No sound coming out of sub woffer
you need an active speaker. plus you need to connect it to the right output on the back of the receiver.
Jan 25, 2014 | Yamaha RX-V375
Technics SA-AX530 all modes not working - no sound
Not a good sign. There should be a click a few seconds after you turn on the unit. That says the output section is OK. If there is no click, you need repair. Perhaps only some fuses inside, but it could be worse.
Also make sure that the speaker switch is in the right position, like A, not A+B. Also the headphone jack can silence the speaker.
Make sure that ALL switches are in the right position.
Dec 17, 2013 | Technics SA-AX530 Receiver
No bass from Bose AM 15 Sub
Sub will only work in surround mode, not stereo mode. Also source must have sub component (5.1, 7.1, 9.1 etc) If your system was transmitting sub signal before, be sure you have chosen a mode which includes a sub signal.
Nov 11, 2013 | Denon Audio Players & Recorders
SOunds shut "off" when changing from HD channel to non-HD channel.
I think you need to look at the sound settings. In particular the type of sound. HD channels often carry AAC sound, suitable for Dolby 5.1 and Standard Channels don't. So the sound system will switch modes when you change channels. However the receiver is not switching back to picking up PCM signals, the type used on SD channels.
Jan 01, 2018 | Harman Kardon AVR 7000
We need the device code of the panasonic Tc42px24 plasma HDTV thank
Hello
Panasonic TV's after 1996 can be set to "Serviceman Mode" with the
following remote control sequence:
-select the SET-UP icon and select CABLE mode.
-select the TIMER icon and set the SLEEP timer for 30 minutes.
-press the ACTION button twice to get out of the menus.
-change to channel 124.
-adjust the volume to minimum (0).
-Hit the VOL down button on the TV itself (not on
the remote) and a red "CHK" should appear in the upper corner.
-press the ACTION and VOLUME DOWN buttons (again, on the
TV, not the remote) you will toggle between AGING and SERVICEMAN modes.
Select Serviceman mode. The POWER button on the remote control will
select one of the five Serviceman Adjustment modes.
The modes are:
B - Serviceman VCJ SUB Adjustments. These include sub-tint,
sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,
audio and video adjustment, and vertical size.
C - Serviceman VCJ Cut-off adjustments. These include Red, Green
and Blue cut-off, red and blue drive, automatic fine tuning
(AFT), RF AGC (RF gain control), horizontal center, beam limit,
etc.
S - Serviceman Options Adjustments. These involce the PIP and
clock.
M - Serviceman MTS (Stereo/SAP) adjustments.
CHK - the mode you first entered. Normal picture and sound, lets
you check things over and still have a hotkey into the
service menu.
There is one more adjustment that isn't in the five modes, it's
global. When in either the yellow or red CHK mode, you can press
RECALL on the remote control to enter the purity field check mode.
This lets you select a pure white, red, green, or blue screen. A
good thing to walk away from if you just want to temporarily freak
out the floor manager, but it will be fixed as soon as the TV is
turned off. Oh well.
To get out of Serviceman mode, press ACTION and POWER on the
receiver simultaneously for at least 2 seconds. The TV will momentarily
shut off and then comes back on.
PE77U / PX75U / PX77U / PZ700U / PZ750U
PD60U / PX6U / PX60U / PX600U
PD50U / PX50U / PX500U :
* Hold down the {VOL -} button ON THE PLASMA TV.
* Press the {RECALL} button 3 times on the remote.
* The Service Menu will be displayed.
* Use {1} {2} on remote to navigate main menu items.
* Use {3} {4} on remote to navigate sub-menu items.
* Use {VOL+} {VOL -} on remote to change item value.
* Write down all values before changing
Once a value is changed, THE CHANGE IS MADE.
* Power off to exit service mode and save
OK.
Feb 13, 2011 | Panasonic Tc42px14 42 in. TV
Clicking noise from Onkyo TX-SR606 during television broadcast
I seem to recall a sub-menu setting having to do with "auto shut off" or something like that.
My receiver is packed up, ready to take to Fry's, or I would find that submenu for you.
Jan 04, 2009 | Onkyo TX-SR606 Receiver
Sr7200 LFE (sub woofer) output stopped working
Chances are if The Receiver only has sound in Stereo Direct Mode and all surround modes and Sub out are Inop the DSP (Digital Signal Processing) Card is most likey defective. These boards are not available from marantz (D&M Holdings) and must be Component level repaired which usually is not cheap. If Only the Sub out is not working check setup to be sure sub woofer is set for on. Also If On Screen setup menu does not appear on video monitor Unit may need to be Reset manually which entails discharging a Capaitor on main P.C.B Contact kstahl65@att.net for details
Dec 16, 2007 | Marantz SR-7200 Receiver
Onkyo Subwoofer Pre Out Problem
May not necessarily be the out put, discontect the sub from the receiver and see if it still makes a hum, Making sure that you turn auto on, off on the sub woffer.
If it still makes a hum, then you have a earthing problem, you can get a earth filter put on your internal wiring in your home, or you can remove the earth pin on your sub woffer
Dec 13, 2007 | Onkyo TX-SR502 Receiver
168 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
