Teka washing showing error 13 - Washing Machines
3 Suggested Answers
Online-Tech
  • 51 Answers
SOURCE: My washer wont spin it shows an error e 13.
If your washer won't spin, check these:
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Thank you for contacting Fixya.com
Posted on Aug 19, 2009
vazrakar
  • 9 Answers
SOURCE: Teka Washing machine manual
use the translate.google.com to translate the language into english
Posted on Jan 04, 2012
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/13 error code on...
The error F/13 is shown on the display due to Dispenser Circuit Error detected in the washing machine.
In this problem check the dispenser motor .Either is blocked or its not running in proper direction.
This will Help.Good Luck.
on Mar 11, 2010 | Washing Machines
TEKA WASHING MACHINE SHOWING ERROR 5 WHY?
Error 5:
Failure information: water intake abnormity
Processing mode: check whether the water hydraulic pressure is too low or watersupply is cut off.
Nov 22, 2016 | Washing Machines
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 | Dishwashers
Error 1 in teka washing machine 1260 WD. What does it mean?
code E1 Main electronic control board failure Unplug the washer. Check the wiring connections on the main electronic control board in the console. If the wiring connections are sound, replace the the main electronic control.
Nov 07, 2014 | Washing Machines
Error 13 showing on teka washing machine and not starting
Suspect the controller unit.
Check this link for tips: Controller
Nov 20, 2013 | Siemens WFXD5202UC Washer
Teka tkx 13wd manual
I`M Korean, I need a 'TEKA tkx 13Wd manual. Please, so hard usually to TEKA washing machin...
My E-mail is
key00519@naver.com
Thank you.
Aug 11, 2013 | Washing Machines
Jan 04, 2012 | Washing Machines
I need a manual for a teka washer/dryer A ls13
We have a Teka washer/dryer A-L512 1200 and all the clothers are comming out with fluff on and the dryer takes too long to dry. We can't find the filters, where are they?
Jul 15, 2009 | Washing Machines
My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
Mar 28, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
