Question about Ryobi RCS3535CA 14-inch 35cc Petrol Chainsaw
Chain saw jammed and would not start - Ryobi RCS3535CA 14-inch 35cc Petrol Chainsaw
I have a 32cc model p3314 it starts but the chain won't move
If you are talking chain saw there is a safety clutch lever immediately in front of the top handle. this has to be back against the handle and when the chain jams you simply push it forward with your fingers and the chain stops
May 29, 2013 | Tools & Hardware - Others
My Husqvarna 350 bogs down and is not turning the chain.
something is pinching the chain when you have the side cover on. either the bar isn't sitting flush to the saw or you don't have the chain in the sprocket correctly and that is causing it to bind
Jan 27, 2013 | Husqvarna Garden
Need help with trouble shooting why my hasqvarna 350 chain saw over reves and will stick
seems your over rev's may be your carb is sucking air it could be the intake gasket isn't lined up properly or the carb mounting bolts vibrated lose
sometimes the over rev is caused by dirty linkage jamming or trigger jam
Nov 03, 2011 | Husqvarna Chain Saw 20" Bar
Chainsaw starts great, but chain wont go
When you tighten the two side nuts, make sure you haven't jammed the chain on the gear. The chain must move freely(by hand) while tightening and when at proper adjustment
Sep 22, 2010 | Ryobi Factory Reconditioned 18" 40cc...
Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Jun 25, 2010 | Echo CS400 18" Chain Saw
Chain jammed wont turn makita chain saw
Make sure the safety chain cut off isn't on. It's on top of the saw and when pushed back will prevent the chain from turning. If that's not the problem take the sprocket cover off and loosen the chain and inspect to see what's wrong.
Apr 28, 2010 | Garden
Remington chain saw, electric: jammed and now the
I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Typed "M30016US" into the "Model #:" window, then clicked search.
  • Click the M30016US - Remington Electric Chain Saw "View Model" link.
  • Click "View Illustrated Parts Breakdown" think you want item 18, 113004-01, Internal Gear
  • Click the 113004-01 - USE REPLACEMENT PART # 122513-01 "View Part" link.
Results follow:
Part #: 122513-01 Price: $24.00
Description: KIT, INTERNAL GEAR (MOD) 747 B/O
If this is what you need I suggest you order it soon.
RemingtonPower has stopped production and replacement pars are almost exhausted. Sooner or later a part you need will be NLA. HTH
Lou
Nov 10, 2009 | Remington M30016US 16" 3.0 Peak Hp Modular...
I have put on a new bar and chain but chain is jamming/loosening
with the chain on the saw and the saw not running, pull the chain around the bar, does the chain mesh with the drive gear correctly? If not, you got the wrong chain or the gear is worn out.
Oct 27, 2009 | Garden
I can start chain saw but cannot get chain and blade to move. What would be causing this
Check the chain brake safety mechanism, see if it is jammed or see if chain has come out of track...
Aug 04, 2009 | Garden
Mccullough chain saw pm610 chain slips -- maybe clutch issue
have you greased your clutch bearing ever.some times they get dirty and tighten up after running a while.pull your clutch off and clean and grease bearing with a little alex grease,and I mean just a few drops.not meant to have a lot of it,too much will burn the crank shaft and you will have more problems then you started with
Jan 01, 2009 | Garden
Ryobi RCS3535CA 14-inch 35cc Petrol Chainsaw Logo
24 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
