Question about Singer 2250 Tradition
I can not get clamp to hold needle singer 7136
5 Suggested Answers
MarkDay
  • 111 Answers
SOURCE: The needle thread is blocked
Threading instructions for similar brother model:
http://www.mastersewusa.com/masmag11901_files/b114_471_721_771_XL711S_info_tg.htm
Possibly lever is to keep bobbin in place? If so, should slide left/right over top of bobbin.
Posted on May 14, 2008
  • 139 Answers
SOURCE: Singer 6038 needle clamp
You can order parts through the Singer parts centers listed on this page:
http://www.singerco.com/support/replacement_parts_ssc_list.html
Posted on Apr 08, 2010
  • 1788 Answers
SOURCE: I have a Singer Ultralock
I have been bailed out by www.sewingpartsonline.com and www.sew4less.com a couple of times for parts on a couple of older machines that I have. They also have manuals for purchase too. I think that I would call them and see if there is a substitute, ie. needle clamp for 14u64 and see if it would work. I know how frustrating it is to try and find parts and manuals, I hate to see a good machine go to waste. Good luck.
Posted on Mar 10, 2011
  • 341 Answers
SOURCE: How do I remove the needle clamp from the needle bar on a Singer Futura Quartet sewing machine?
try undoing the lock screw fully and gently move the clamp in the opposite direction the the lock screw, it should drop off.
Posted on May 30, 2012
I can't move the needle clamp to change the needle on new Singer 2250 Traditional. Can you help?
Here's the manual with the instructions:
SINGER 2250 Instruction Manual Inserting And Changing Needles
The screw that holds the needle in place also has a slot where a screwdriver can be used to apply extra pressure.
May 07, 2017 | Singer Sewing Machines
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
How to replace a needle in a Singer Ikea 150 year anniversary game boy edition
If you take a look above the needle, there is a clamp on the shaft with a screw, generally on the left side. That is called the "needle clamp." Put something under the needle first, then loosen the screw on the clamp, and the needle will drop out. THAT'S why you need to put something under it--if you don't it will drop into the bobbin area and can be hard to fish out.
Take a look at the needle you want to insert. It will have a flat part, and that flat part MUST be away from you--facing the back of the machine. Insert the needle as far as it will go (holding it with needle nose pliers works great for this) and tighten the screw. If the screw does not have "wings" on it, after you have hand-tightened it, use a straight-blade screw driver and tighten it at least 2 or 3 times more.
Feb 19, 2015 | Singer Sewing Machines
After replacing the needle in my singer 8280, the needle clamp is not holding the needle tight, the needle falls down even after tighening it..how do i make the needle get fixed?
It sounds like you have lost the tread guide. When you press the clamp as far up as it will go, there should be a slot in the post underneath the clamp visible. You may need to use a mirror to see it. The thread guide snaps into that slot and keeps the clamp from falling down. Take it to any repair shop. It will not be expensive to repair.
Nov 30, 2014 | Singer 8280 Mechanical Sewing Machine
I need a manual for a singer sewing machine model 7136
You can download your manual free at the Singer Sewing Machine site.
Jan 08, 2012 | Singer Sewing Machines
I have a Singer #7430 hardly used, but I thought the needle should be changed as it sounded dull, now i cannot get the needle to stay in when i start sewing the needle falls out and i have broken 3...
some needle clamp screws have a indention where a screwdriver can be put in to turn the screw,,
check to see if your has the indention & if not you need a new needle clamp screw
Nov 04, 2010 | Singer 7430 Sewing Machine
Singer 2250 Tradition Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
