How can I reinstall system on Cowon A3, after formatage ?
I have reformatted the HD of my Cowon A3 and put the firmware files on root. The A3 doesn't update the firmware. It seems there is a problem with the .system folder which has disappeared with the formatage... Where and how can I find a new .system folder ? Thanks in advance.
Inky
  • 691 Answers
SOURCE: Archos 605 Recovery code 108
1. Download the latest firmware from Archos
2. Format the drive on your player
3. Connect the A605 to your computer using the USB lead
4. Copy the new firmware the A605's root folder (Drive X: on your PC or whatever letter was assigned to your Archos
5. Click ok and you are finished
Posted on Jul 03, 2008
SOURCE: Cowon A3 display 'unsupported codec' when VOB file is played.
The Problem is solved with the Firmware - Version 1.23 all newer Firmware can't play VOBs, because there is a License - Problem
Posted on Nov 21, 2008
  • 10 Answers
SOURCE: Firmware update issue
The firmware file isnt a VLC file it is a .bin file you can get the file off sumvisions website http://www.sumvision.com.cn/drivers.aspx it is the second one down.
Posted on Aug 15, 2009
  • 5 Answers
SOURCE: Send music to Cowon D2 but when I try to play, it says no music
Your d2 must have been affected by virus which has hide your music folder so unhide the music folder
Posted on Aug 29, 2009
Testimonial: "Thank you this worked, everything is great."
YourZEN
  • 820 Answers
SOURCE: How do i update the firmware for the VP8870? Ive
While performing firmware update all data will be erased !
See the manual on page 36:
Vosonic VP8870 manual
The firmware update for the player is PMP.VP8870-1.0.0.B2.mtg :
Since you've downloaded the zip file, were you able to unpack it with
Winzip op Winrar ?
When using XP you can unpack by:
1. [Right click on the zip file] Open with > Compressed maps [left click on Compressed maps]
2. The next screen shows the opened zip file. On the left side the
folder task manager can be opened ( Folders / Maps in the top bar not selected): "Unzip all files" : follow up the Windows unzip wizard and
remember the location of the files.
How to do the firmware update is explained in the pdf file "How to update 1.0.0-B2 - VP8870 .pdf", added to the firmware update in the
zip file.
Remember:
Posted on Sep 12, 2009
Cowon iaudio 10 frozen
Hi. I had problem like this, now resolved. My device is iAudio 9+ otherwise it's not matter.
You can find some solutions on the web but... maybe you can not do proper result first or second time. It comes because of some differences for so lot of devices.
I used this method.
How To Recover your Bricked J3 using Tcctool iAudiophile net Forums
Only one way working for me.
1. Prepare drivers and firmwares. Tcctool and Windows drivers for USB flashmode. Latest FW for your iAudio from Cowon Korea site. Unpack all files/folders into special directory in root of your Hard Drive (c:\COWON for example).
2. Boot your PC in compatibility with non-authorised hardware mode. Press F8 button when PC loading and choose Drivers signature disabled mode.
3. Turn off your iAudio with reset button. Press both M(enu) and VolUp buttons and boot on power. Screen doesn't fire but device standing up in flashmode. Connect USB cable to device, then to PC. On Windows Device Manager you must find new Unknown Device. Install drivers manually from your specific directory.
4. Run on PC new task CMD, e.g. terminal window. Change work directory to your specific, f.e. cd c:\COWON
Run execution tcctool.exe -d cowons9 "name of your FW file"(without quotes).bin
Attention, your FW file (iaudio9P_fw.bin for me) must be in same directory with executable tcctool!
5. After flashing your iAudio must be connected to PC immediately as USB flash device. So you must copy all firmware files (named *.bin) to root of your Cowon device memory. Then reboot, your player must updating firmware and working fine. If still no, try use tcctool to boot on once more, then reboot normally. Copying FW files again doesn't required.
Hey you don't give up!
Mar 31, 2014 | Cowon Iaudio 10 16gb White
The system folder is empty on my Cowon e2mp3 player. How can I reinstall the hardware Cowon is impossible to reach by phone
Is it an iaudio E2? If it is, you can go to www.cowonglobal.com and download any drivers, firmware updates, and hardware from there. If it is an older unit you may have to contact them directly as this is the only E2 I see listed on their website.
Apr 19, 2013 | Audio Players & Recorders
After trying to update FW of my Cowon D2/4GB I've got just empty screen. When exploring I see 6 folders containing: MUSIC - empty; PICTURES - empty; RECORD - 4 empty subfolers; SYSTEM - 5 files:...
Hello there, what has happened to your unit is simply a situation of corrupt filing or an incomplete firmware update installation. When this situations arise it is considerably difficult to fix as the unit mostly does not initialize to start up the installation process to enable you re-install the fresh firmware. This problem is generic with the D2 as a lot of people have encountered the same problem. Best situation is return it back to the local dealer as this seems to be the best way out.
Hope this solution has been helpful?
Thank you for visiting FixYa.
Jul 24, 2011 | Cowon System Cowon D2 Digital Media Player
My comp do not turn on it say windowa root)systemre/ha1.d11. what happen
You are missing a critical boot file. Reinstall windows.
Feb 28, 2011 | Computers & Internet
Problem in R4
sounds like you're going to have to send it to nintendo for repaire
the system files are the ds's operating system if they are damaged than it cant play games
Sep 20, 2009 | Nintendo DS Lite Console
Cyclone media player firmware problem
Sumvision Cyclone Latest Firmware Update
Latest release of firmware to fix customer who may be experiencing "menu" problems or large HDD problems:
Please download the .zip file from the link below:
http://www.digitalpromo.co.uk/images/cyclone%20upgrade.zip
Then follow these easy installation instructions:
Info: Hard drive must be either new or contain very little data for this update to work.
1.) Extract the file
2.) Put it in the root of the HDD
Note: Dont change the file name, dont put it in a folder
3 .) Power the device on, go to the "setup" section, and click the upgrade firmware
Regards
Sep 03, 2009 | Electronics - Others
Can't hear audio book files on my d2
because audio book can be played in d2 firware 4.58 just go and download the firmware from cowon site and update it then u will be able to play audio book
Jun 26, 2009 | Cowon System Cowon D2 Digital Media Player
Nov 07, 2008 | Cowon System Audio Players & Recorders
61 people viewed this question
 Grubhead
Grubhead
