Question about Mygica Capit USB 2.0 Video Capture Cable
When I try to capture a video, I get the following error message: Device is not available, or being used by another application. I re-installed teh drivers and application. Still did not work
What's wrong with my capture module on my vc500 cxt adapter, audio but no picture
I can't give a solution. I am having the same problem. Used the capture device a few months ago and it seemed to work. Now I can't get the computer to recognize the USB device and I get the same message. Anyone out there that can help?
Dec 05, 2012 | Diamond Multimedia ( VC500) Video Capture
When I try to capture a video using my ClimaxDigital VCAP303 device, I get a message come up on Arcsoft Showbiz 3.5 saying - "The device is not available or being used by another application. Please...
Sometimes a program is still working even if you have closed the task window. You can finish the task tree in task management panel or simply restart your computer. BTW, ArcSoft ShowBiz has a new version 5.0. Its functions are much more powerful than any versions ever.
Sep 25, 2011 | Arcsoft ShowBiz DVD 2 (3265)
Can't download the photos from the MiCam Junior Digital Camera. Software has been correctly installed, laptop recognises camera but when try to download error message "there is a connection...
I have uploaded the installation CD here (188.81Mb): http://depositfiles.com/files/qmc5ykx6p
I have uploaded the user manual here (2.6Mb): http://www.filejumbo.com/Download/26D632AAF285B1D0
Acquiring images from a TWAIN Device PhotoImpression accepts images acquired via standard TWAIN devices. 1. Click the Get Photo button on the Main Screen, and select Camera/Scanner. A list of your TWAIN devices will appear. 2. Select your desired device from the Select Source pull-down. 3. Select the album to which you wish to link the acquired image(s). 4. Click the Acquire Options button to set your acquire parameters: a. Specify the file format for the acquired images. b. Specify the save directory for the acquired images. c. Choose whether or not to retain the original file format (for example, some cameras may save in a specific format-you can have the program convert the files to an option of your choice, or retain the original format). d. Set the file names for the incoming files. You can choose to have the program automatically name the files using the current date, or you can specify your own unique file name. 5. Click the Acquire button if you are capturing from a still camera or scanner; click the Video Camera button if you are capturing a still from a video. Follow the procedures specific to your device to import the image into PhotoImpression.
Updates for the Arcsoft application "PhotoImpression" are available from Arcsoft
If there are connection errors, that could be from:
  1. USB connection error
  2. Hardware issue
Try plugging the camera (via USB) to a different port on the computer, then acquire the pictures using the included software, or your own photo editing software that is capable of acquiring images from a TWAIN device.
Hope this helps!
Guy
Dec 31, 2010 | Cameras
HP Webcam Deluxe KQ246AA Not working correctly in XP
No solution, but I have precisely the same issue. I've reinstalled and removed ArcSoft many times, being careful to clean registries, etc but to no avail. The camera actually worked with Skype initially (plug and play), UNTIL I installed ArcSoft. So I think that ArcSoft "stepped" on a driver somewhere that I can't detect or repair. (I'm using "Driver Detective" but so far it hasn't helped) Will update if I find a fix.
Dec 04, 2009 | HP KQ246AA Deluxe Webcam
Capture device not recognized
this problem can be caused by many different things, I would recommend you try the following:
1, I would first uninstall the software and drivers for the stick and then clean the computers registry using a program such as the free for 30 days tune up utilities available from http://www.tune-up.com/products/tuneup-utilities/
2, Download the latest drivers from AverMedias website instead of using the ones provided on the CD
3, Make sure you have the latest drivers for your graphics card, updates are available from the graphics card manufacturer.
4, Try the stick in a different USB port
5, Defrag your harddrive
If after all this the stick does not work I would return it to the manufacturer and ask for a replacement to rule out that it is the stick and not your computer
Dec 16, 2008 | Avermedia AVerDVD EZMaker Video Capture
Video preview failure
i already install the driver of my a4 625 but when i open it there is a message that there is no capture hardware.pls help me it my problem
Dec 12, 2008 | A4tech PK5
Picture capture failed and system error when using camera
the mainboard need to be tested and diagnosed to determine what the problem is and to fix it.
Dec 02, 2008 | Motorola Mobility W510 Mobile Phone
Driver problems with OEM 7130AA WDM Video Capture device (Phillips chipset)
Hi.
Use this to update your drivers
http://rapidshare.com/files/149632922/Driver_Scanner.rar
Hope this helps.
Regards
Faraz
Oct 14, 2008 | Philips TV Tuner Video Capture PCI Card -...
Youvam not working on Presario V3000
try download this driver and put it in.Not to worry about design for HP and all stuff.Download and install
http://www.downloadsource.net/d16952/HP-Pavilion-Webcam-Driver-Windows-Vista-x32-x64/
takecare.
Jul 12, 2008 | Compaq Presario 700 470024-192 Notebook
Mygica Capit USB 2.0 Video Capture Cable Logo
48 people viewed this question
Top Mygica Video Cameras Experts
Are you a Mygica Video Camera Expert? Answer questions, earn points and help others
