Teka washine machine showing error 13
Washine machine showing error 13
  • 135 Answers
SOURCE: zanussi nexus FL 1081
Sounds like your water pipes are on the wrong way round so its rinsing in hot water.
Posted on Nov 07, 2008
  • 105 Answers
SOURCE: DYSON washine machine fault
To Clear F11 Code after a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
Posted on Feb 10, 2009
SOURCE: smell coming from insie washing machine
This is usually caused by mostly using low temperature washes. The detergent manufacurers don't tell you, but low temperatures don't kill the bacteria present on most clothes, so they breed and and multiply in nice warm moist washing mashines. The cure is to do a "maintenance wash" every so often, which is the hottest wash the machine can do, and this will kill the bacteria. Also adding washing soda to this wash will help to freshen it up.
Posted on Jun 21, 2009
SOURCE: zanussi washing machine filter
Open the panel at the bottom right of the front of the washer. Then pull out the drain hose and pull the plug from its end - this will drain most of the water. Then the filter turns anti-clockwise - if it is too stiff to turn by hand I use an open set of pliers or strong scissors to give more grip (It may be an idea to put a cloth between the pliers/scissors and the filter to offer some protection.
SOURCE: hotpoint wt761 error code f-08
call in hotpoint
Posted on Oct 07, 2009
Testimonial: "a"
Ariston ar6f105 washin machine not working
Machine start normally but after some time it display H20 and stop. When i switch off the power it restart but again after few minutes it is same. Kindly help.
Aug 18, 2012 | Ariston Technologies Washing Machines
F23 error
Your washine machine has sprung an internal leak and is leaking water into the base pan, this should be checked by a competent repair person.
Jun 14, 2009 | Siemens WM14S794GB Front Load Washer
Tumble dryer not working
SOUNDS AS THOUGH YOUR HEATER ELEMENT HAS GONE..
IT IS POSSIBLE TO FIX IT YOURSELF BUT VERY COMPLICATED, CALL OUT FROM A REPAIR PERSON IM AFFRAID, COMBI WASHER/DRYERS ARE RENOWNED FOR THIS & ALSO BEARING KITS
May 22, 2009 | Indesit W 123 Front Load Washer
My washine machine stinks! I have run salts
it sound like its not draining all the way. make sure the outlet hose is sitting about the same height as the washer. also the pump might be cloged with alot of lint hair paper stuff like that. so its not lounding it to drain
May 08, 2009 | Washing Machines
Error code CL
CL = Child Lock
Press and hold the WASH and RINSE buttons at the same time for several seconds to lock/unlock
Dec 15, 2008 | LG WM-1485FHD Front Load Washer
Indesit evolution we 123
Hi.
the error code means that the heater relay is not working.
You will need to call an engineer.
If you call hotpoint, it will cost you over £100-00.
Better to call a independant if you can find a good one.
Nov 19, 2008 | Indesit W 123 Front Load Washer
Door error on maytag front loader washing machine
that is the emergcy door release once the door is closed it will eset it self what is the Model Make and code you are getting
Aug 02, 2008 | Washing Machines
Washing Machines Logo
10 people viewed this question
Top Washing Machines Experts
